Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Can I run a 944 Turbo transaxle without the cooler loop?
I have an opportunity to buy a Turbo transaxle that originally had the oil cooler loop. Is there some type of block off plate that I could use if I didn't want to use the cooler? Would it be ok to run it this way? I am asking because the seller has no cooler to go with the trans.
Old 10-05-2014, 12:28 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
No, that transaxle has an internal oil pump. You can add another oil cooler radiator and lines for cooling. Recommend Mocal oil coolers core with 22,000gw and the proper an 12 lines and fittings. Heat is a big issue above 200hp with our cars...
Later.
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 10-06-2014, 02:56 PM
No, that transaxle has an internal oil pump. You can add another oil cooler radiator and lines for cooling. Recommend Mocal oil coolers core with 22,000gw and the proper an 12 lines and fittings. Heat is a big issue above 200hp with our cars...<br>
Later.
Thanks for the info. I suspected that this was the case, but I wanted to be sure.
Old 10-06-2014, 06:23 PM
911tracker85's Avatar
OK .... I am starting on a clutch replacement on my '86 951.
plan to drop the transaxle/torque tube.
was wanting to investigate tranny cooler options while it is out.
suggestions? and I mean sources, kits, etc. I am OK with putting together stuff, but would like to feel it will be successful.
in full disclosure, I have not done a search yet.
thanks, looking forward to ideas.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 10-09-2014, 09:31 AM
Pete R's Avatar
BAT(Britiash American Transfer) inc can probably help you out. They sell Setrab and Mocal coolers. One guy really knows his stuff. The woman's kinda *****y and the other guys an idiot but the one guy knows everything and will have no problem with this. (I'm trying to locate his name in my paperwork but haven found it yet)
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 10-10-2014, 05:10 AM
Pauld_94S2's Avatar
Here's a source that I use:
transmissioncoolers.us: Tru-cool thin coolers
I have installed several Tru-Cool automatic transmission oil coolers on different vehicles and had good results with each one.
You will have to see if any will work in your application.
Old 10-11-2014, 10:58 AM
