Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Educated Grease Monkey
speedfrk's Avatar
Help! My fqs switch snapped off while trying to adjust.
Ok so here is what happened. I used the tutorial for adjusting the dme fqs switch in order to try and remove some fuel enrichment from the stock table. I used the 2.5 mm Allen wrench and the potentiometer switch snapped off. I couldn't get it to turn and now have no idea what setting it is on. I can now turn the pot switch but because the stop is gone it can just spin and spin. I am not really sure what to do here...I want to set it to position 2 for the -3% fuel enrichment with no timing retard. Is there any way to identify which position the pot is in without the stop?
83' 944 N/A - Guards Red - Minor mods - SOLD
87' 944 Turbo - Alpine White - SOLD
88' 944 Turbo - Guards Red - Garrett T04e-57 Turbo, Tial 44mm, 55lb/hr injectors, 951 maxx chips...planning MS or Ostrich-2 for tuning very soon!
DRIVE IT LIKE YOU STOLE IT!!!!
Old 09-14-2015, 02:57 PM
soxnail's Avatar
It is actually not a pot but a switch.
If you broke off the stop point you should still be able to feel the switch change settings, it will be a soft click definitely felt.
IIRC there is a bigger gap in the "clicks" when it goes from 7 to 0 all the rest should be shorter so you could figure out where 0 is and set to 2 more clicks from there.
Do not keep spinning it around as you will wear out the stop hitch that produces a click. Then your choice will be to open the DME and use a meter to set it or replace the switch.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 09-14-2015, 05:34 PM
speedfrk's Avatar
Thanks for the advice. I'll give it a try tomorrow.
Old 09-14-2015, 08:21 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Scary stuff....
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 09-15-2015, 06:36 AM
