Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Send a message via AIM to sempaipaul
Help needed identifying a DME wire.... please!
Hi guys.
See the first pin (or last as I am not sure where the pin numbering starts) --- there is a yellow wire that is tapped in there. The wire doesn't connect to anything but, I am curious what the intent may have been.
Any thoughts?
Thanks!
Paul
03' Audi RS6; 16' 328i xDrive Touring; 13' X3 mSport, 91' e30 M52
Old 08-19-2017, 12:10 PM
There should only be the green wire there and it goes to the coil. (From the '88 turbo wiring diagram)
Did the car have any aftermarket products installed that would need a coil input?
By the way, you can see the pin numbers on the connector. Most connectors are marked similarly helping in troubleshooting from the wiring diagrams.
Bruce P.
2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 08-19-2017, 07:16 PM
More Boost!
Old 08-20-2017, 08:06 PM
