Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
soxnail's Avatar
Quick note,
When redoing the ball joint at the control arm, in the instructions it says remove the circular clip...be warned the spring under it will propel the bottom plate at a high velocity to parts un known.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 07-03-2018, 08:04 AM
soxnail's Avatar
The control on the passenger side was replaced (supposedly) about 15 years ago....
looks like it was rebuilt with a kit of some type.
Has any one seen this particular rebuild of the ball joint ? and can I just leave the other zerk in there and just do the Rennbay rebuild ?
The arm on the driver side was normal and rebuild went fine.
Thanks and Happy Independence day.
Old 07-04-2018, 09:43 AM
In the Fires of Hell.....
kdjones2000's Avatar
Just leave it in there, and go ahead. Mine were like that as well.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 07-04-2018, 01:05 PM
soxnail's Avatar
Thanks Keith,
The silver stuff was JB weld not aluminum.
Already done.
Sox
Old 07-04-2018, 02:39 PM
