check engine light will not come on
I have a 95 993. I went to get a smog check and the car passed with flying colors except...the check engine light would not come on with the ignition key on.
I checked the bulb which was fine and actually replaced it just to make sure. Before I go any further any suggestions out there?
Old 12-04-2018, 05:58 AM
That's strange. I checked the wiring diagram and the CEL is directly connected to the DME.
regards
Hans
Old 12-04-2018, 10:56 AM
Cobalt's Avatar
Did you check for voltage to the bulb? Check all contacts? Could be any number of things from a broken wire, corroded contact or the DME.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 12-05-2018, 06:20 PM
