tcsracing1's Avatar
964 turbo A/C compressor rebuilders?
I pulled the A/C compressor from my 55k mile 1991 turbo.
Given how hard it is to get a replacement, is there anybody rebuilding them?
WANTED: 1967 Transmission #103586
1967 Transmission #200082
1969 Engine#6195922
1969 transmission#7194313
1969 transmission#7195495
Old 05-05-2019, 07:00 PM
kuehl's Avatar
True "Rebuilding", would require, jig bore, jiq grind or at least a good honer.
Matching oversized pistons to enlarge bores. Removing a difficult to remove
swash plate, matching of some half bearings. And, in severe cases replacing metal.
I'm gonna say the normal 'rebuilding, re-manufacturing, repairing, etc.' service market will be limited to replacing seals, o-rings and maybe a few bearings, sprinkling some Becks on it for good measure.
It all starts with a teardown to see what is worn, such as pistons, bores, swash plate, reed valves. If they all look good and there are no metal particles or signs of grey matter, you might get away with a seal kit.
Clutch wise, you could replace the bearing, maybe fly cut a mil or a few thousand off the clutch faces, difficult to repair a toasted clutch coil or re-vulcanize on some rubber, at best if its a spring steel plate, drill out some rivets, replace the springs, and re-rivet.
If they say its a 'rebuilt, remanufactured or whatever' factory' Denso or Nippondenso, ask by whom? It should be in Denso box with a new Denso label on it.
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 05-06-2019, 02:16 PM
tcsracing1's Avatar
anywhere that i can send it to see what is possible?
1969 Engine#6195922
Old 05-07-2019, 09:39 AM
kuehl's Avatar
I'd suggest you tear it down yourself.
Not that difficult.
Get yourself old clean cookie sheet with sides.
Empty large coffee can.
Some metric sockets, snap ring pliers, metric hex socket (6mm)
Bench vise.
Turn puppy over the coffee can so ports aim in it.
Turn the outer clutch hub bolt head a dozen times in both directions.
Tilt it left and right, drain out as much oil as it might have (little to 1 oz).
Take the clutch face plate bolt out (air gun).
Pry of clutch face.
Take of snap ring.
Take off pulley.
Take off snap ring.
Take off clutch coil.
Hold compressor by its mounting ears (things the comp bracket bolts go through),
carefully in vise. Remove long allen bolts.
Move comp over to cookie sheet.
Take off back side with reed valve and plates.
Take off nose (what clutch was on).
Carefully inspect bores, pistons and swash plate (the funky round aluminum disk on the shaft that pistons slid over). Inspect reed valves. If no wear and no grey or black matter, put it back together with a seal kit. If question get a new Denso compressor and move on.
Kuehl
Old 05-07-2019, 01:37 PM
tcsracing1's Avatar
I removed the original A/C compressor.
I have since installed another compressor from a low mile car.
My original Denso only has 55k miles on it but wasnt working.
Given how hard it is to buy a correct unit for a 1991 turbo, i was wondering if my unit has any value?
1969 Engine#6195922
Old 05-08-2019, 10:57 AM
kuehl's Avatar
Toss it up on Pelican Classified
Kuehl
Old 05-08-2019, 11:35 AM
How's your replacement unit working ?
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 05-13-2019, 02:23 PM
tcsracing1's Avatar
Will be taking the car out of winter storage next week and running it all summer.
It was working great once it was installed last year!
1969 Engine#6195922
Old 05-23-2019, 05:32 AM
Good ... I'm glad it worked out
1992 964 C2 turbo
Old 05-23-2019, 05:53 PM
