Alarm 964 turbo startermotor problem
I have had a long time problem that startermotor
don’t pull all times.
I have previously changed ignition switch and startermotor.
on a 964 turbo the cable goes straight no relay according to wire diagram.
anyone know it’s way and we’re the split at the Porsche alarm could be?
Old 01-13-2024, 01:38 AM
jm993rs's Avatar
Today my 964 but start the emergency lights and not start !!!
Last days when I open with the key times not open the other door ….. and when I input the key on the starter I see the 4 lights intermitent working …..
I down of the car return close the car …. And return open and is disconnected !!! And the car start without problem ……
And today I have the same step problem but never can stop the emergency lights and not start the car …..
I disconnect the battery and always when I return conect start the 4 lights emergency and the car not start engine 🙈🙈🙈🙈
Please I need help for where I can start to repair this problem !!! 🙏🏻🙏🏻🙏🏻
Old 02-14-2024, 03:51 AM
Cobalt's Avatar
Do you have an aftermarket or 993 alarm installed> The 964 never had a key fob actuated alarm. That looks like the 993 alarm key fob. If so the 993 units are notorious for acting up this way. The capacitors leak and can create a short that acts like a ghost in the machine. Sometimes it works sometimes not. I would first check to see what you have installed.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 02-14-2024, 05:38 AM
