ab3 ab3 is offline
Rate my rust
I'm making some progress on the car and wanted to poll the veterans in here, so I can figure out the best way to move forward. On a scale of 1-10, how bad would you consider this? In your opinions, how would you approach this? I know very little about bodywork, so I'm not sure on what's possible. I appreciate the advice!
Old 06-23-2025, 06:06 PM
Cobalt's Avatar
8.75 out o 10. The windshield needs to be removed and the material excised and new metal welded in place. The rest needs to be addressed one at a time. Some of it might be able to be wire brushed and coated with a rust encapsulating paint. i would also replace all or as needed, brake, oil and fuel lines if it is this rough shape.
Was this car sitting in brackish water for any period of time? Other concerns are the ABS module. Usually when I see rust like this the module is toast. The connections get wet and the pins rip out of the unit when the harness is removed. being a C2 it is a less expensive problem than if it were. C4. C2 ABS brains are cheap in comparison. Shocks look as though they could be changed by now if they are original which they appear to be.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 06-24-2025, 03:27 AM
faverymi's Avatar
My fear is how much more rust is there hidden...
If you take that car apart you will be negatively surprised
I think there is a lot more. Sorry
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 06-27-2025, 05:12 AM
Cobalt's Avatar
No doubt it will grow but it can be repaired. It all depends on how much you're willing to put into it.
Old 06-27-2025, 05:36 AM
That's brutal. Was this a saltwater flood car?
Andreas
1995 993 Coupe, Polar Silver / Black
2014 Audi A4, Monsoon Gray / Black
2002 Toyota 4Runner, Dorado Gold
2001 Toyota 4Runner, Dorado Gold, 600,XXX 1-owner miles
1998 Toyota 4Runner, Oxidized, 5-speed
Old 06-29-2025, 05:49 AM
Hi
Which countries(s) has the car been operated in ?
Operated in the Winter on salted roads ?
Road salt will strip off Zinc plating very quickly followed by crusty rust.
Remove rusty parts and blast and re zinc plate or replace with new parts.
Cheers
Old 08-10-2025, 01:36 AM
Andreas
Also curious about the history here.
Old 09-09-2025, 07:56 AM
