WydRyd's Avatar
Question Installing a 964/993 Distributor?
How easy/difficult is it to do this? Is it a DIY install?
I want to remove my Carrera distributor and fit in the reman'd 964/993 unit I have in my possession, but just running it in single mode until I get a second Crane Ignition & Coil to drive the dual distributors.
Is it just a matter of dialing the crank to a certain point, removing the single distributor and dialing the new distributor to the exact same point and installing it in place?
Advice appreciated.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 04-04-2006, 06:07 PM
AFJuvat's Avatar
It is the same as installing the regular distributor.
Set the motor to TDC #1 and set the distributor to just before TDC #1. as you insert the distributor, the rotor should spin and line up with the mark.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 04-04-2006, 06:51 PM
Yeah, set the crank pulley to Z1 or TDC on #1 cylinder.
Remove the original dizzy cap and note the rotor position to make sure it is pointing to #1 spark plug. Pull the dizzy out.
Remove the cap on the 964 dizzy. You should see a triangular marker along the rim of the body.
That is the TDC #1 position for the rotor.
The dizzy pinion gear is helical so you either have to advance or retard (not sure)
the rotor position prior to insertion so when it is fully seated, the rotor lines up with the triangular marker.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 04-05-2006, 02:50 AM
WydRyd's Avatar
Cool, great info there. Thanks
Merv
'89 911 Turbo Cab
Old 04-06-2006, 04:08 PM
