ecm911's Avatar
Need check list for chain housing reseal
Hello,
My chain housings are leaking and I am consider drop the engine and resealing myself. Srarting the search for checklist;
1. Engine removal ( I have)
2. Chain (cam) housing reseal - need
3, Cam timing, if not included in #2
4, While there I may replace the clutch , need
E
PS car is 3.6 964 RSA 1993
78 SC Coupe
93 RSA (Gone)
Old 04-12-2006, 05:01 AM
Bill Verburg's Avatar
The fittings that feed the hyd tensioners are callled bridges, they often are the source of leaks in the upper chain case area
2x bridge 964 107 088 03
2x o-ring 999 701 909 40
2x sealing ring 999 701 889 40
Bill Verburg
Old 04-12-2006, 12:52 PM
Bill,
Should I be replacing the actual "bridge" piece? I've got my engine torn down, and figured I'd replace the gaskets, and o-rings, but not the actual "bridge". Do they actually wear out?
Thanks,
-Eric
90 C2
NER/PCA
Old 04-12-2006, 06:29 PM
I replaced the whole bridge, they were ~$33ea. o-rings ~$.40 ea.
Bill Verburg
Old 04-12-2006, 07:38 PM
ecm911's Avatar
How much of this can be done with the engine in the car?
78 SC Coupe
93 RSA (Gone)
Old 04-13-2006, 07:35 AM
Not a whole lot can be done with the engine in the car.
The engine tin needs to be removed to remove the chain cover.
If you need to replace the seal between the chain housing and the engine block, you need to take out the cam sprocket and have to re-time the engine.
Old 04-13-2006, 07:51 AM
ecm911's Avatar
Bill,
It looks as if the bridges can be replaced without disturbing the cam timing. Am I correct ?
Thanks,
Earl
78 SC Coupe
93 RSA (Gone)
Old 04-17-2006, 09:14 AM
Yes, no need to drop the engine either
Bill Verburg
Old 04-17-2006, 09:57 AM
ecm911's Avatar
Thanks Bill!
Any other suggestions for changes that can be done without droping the engine ?
I first want to clean the area real good and find out exactly were the leaks are.
Earl
78 SC Coupe
93 RSA (Gone)
Old 04-17-2006, 10:32 AM
