Need check list for chain housing reseal
Hello,
My chain housings are leaking and I am consider drop the engine and resealing myself. Srarting the search for checklist; 1. Engine removal ( I have) 2. Chain (cam) housing reseal - need 3, Cam timing, if not included in #2 4, While there I may replace the clutch , need Thanks E PS car is 3.6 964 RSA 1993
78 SC Coupe 93 RSA (Gone) |
The fittings that feed the hyd tensioners are callled bridges, they often are the source of leaks in the upper chain case area
2x bridge 964 107 088 03 2x o-ring 999 701 909 40 2x sealing ring 999 701 889 40
Bill,
Should I be replacing the actual "bridge" piece? I've got my engine torn down, and figured I'd replace the gaskets, and o-rings, but not the actual "bridge". Do they actually wear out? Thanks, -Eric 90 C2 NER/PCA |
I replaced the whole bridge, they were ~$33ea. o-rings ~$.40 ea.
How much of this can be done with the engine in the car?
Not a whole lot can be done with the engine in the car.
The engine tin needs to be removed to remove the chain cover. If you need to replace the seal between the chain housing and the engine block, you need to take out the cam sprocket and have to re-time the engine. |
Bill,
It looks as if the bridges can be replaced without disturbing the cam timing. Am I correct ? Thanks, Earl
Yes, no need to drop the engine either
Thanks Bill!
Any other suggestions for changes that can be done without droping the engine ? I first want to clean the area real good and find out exactly were the leaks are. Earl
