Tec3r driven Varioram
Does anyone know if the Electromotive Tec3r can drive a Varioram intake? I know it works on the Plastic 993 intake secondary system but don't know enough about the Varioram to be sure about its integration. Anyone with information on joining these two systems would be appriciated. If I knew what the variorams computer driven signal where based on that info might also help.
Thanks in advance! |
all you need is a spare rpm signal and a vacuum source, I've been looking into running Motec w/ vram
I still don't know how to connect it... The Electromotive tec3r uses RPM and MAP to determine when to activate the vacuum relay. I need to know step by step how to connect this to a stand alone ECM. I used the tec3 to control the 95 993 plastic intake with no problem because it was only RPM based. I'm still confused about the Vram installation.
Pictures would also be helpful. Thanks |
