| Moderator |
				Phase 5, Done
			Phase 1, RS Aerokit   Phase 2, RS brakes Phase 3, G50/30 Cup transmission Phase 4, Full JIC Comp suspension, TRG adjustable bars, lowered, corner balanced, Unbelieveable handling Phase 5, 3.8RS installed in '95 coupe                 Weather finally broke, finally got a chance to play w/ phase 5, Ausgezeichnet!!
				__________________ Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | | ||
|  03-13-2007, 08:31 AM |
| Registered Join Date: Nov 2004 Location: Planet Earth
			Sweet
				__________________ Downshift | ||
|  03-13-2007, 08:52 AM |
| Sports Purpose 911 Driver Join Date: Mar 2002 Location: La Jolla, CA
			nice work Bill.
				__________________ James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress | ||
|  03-13-2007, 05:02 PM |
| Registered |
			But, but , but ... it has AC in it!  You figure the 3.8 has the extra power to run it in a race too?    Thank god the class rules prevent me from doing a 3.8.  I have to live with a 300 hp putt-putt rthat's a bit over-weight. It looks great. Our 70's and sun have made me yearn for track dates and I have to wait another couple weeks before getting back out again.
				__________________ Tom SL63 AMG Daily Driver '92 964 now a GT3R/GTL toy for track fun (Tom's Turtle) | ||
|  03-13-2007, 08:48 PM |
| Moderator |
			WOW!  I'd love to go for a ride one day... ...or maybe it would be a lot better for my wallet if I didn't.
				__________________ Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne | ||
|  03-14-2007, 10:36 AM |
| Moderator | Quote:
|  03-14-2007, 04:09 PM |
| Moderator | Quote:
|  03-14-2007, 04:11 PM |
| Registered |
			looks like the heater blower has been removed though. nice, bill.
				__________________ To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) | ||
|  03-21-2007, 11:30 AM |
| Registered Join Date: Aug 2003 Location: Apex NC
			nice bill    I need a /30 for my car
				__________________ ... 59 356a Coupe .... .... | ||
|  03-22-2007, 10:10 PM |
| Moderator |
|  03-27-2007, 12:06 PM |
			solid lifters?
|  03-27-2007, 12:30 PM |
			drop me an email Bill, have some pics of a Timmons based exhaust I did to share with you.
|  03-27-2007, 12:31 PM |
| Moderator | Quote:
|  03-30-2007, 01:43 PM |
			was there any difference between hydraulics? were they all the same part number? I see to have damaged mine by running 15/50 oil. I have lifter tap, no too bad, but enough to be annoying.
|  03-31-2007, 07:40 AM |
| Moderator |
			there are 3 lengths of hyd. lifter.  The longer ones are only used if the valves seats are moved from the standard stock position possibly be a valve job or seat replacement. 15/50 shouldn't have caused an issue. They are wear parts w/ the polymer seals being the most fragile parts
|  03-31-2007, 01:50 PM |
| Registered Join Date: Mar 2007 Location: Texas
			Fantastic!  Nice work.  IMO Your car is the ultimate especially the color.
|  03-31-2007, 09:00 PM |
			thanks Bill. the way Tyson built the engine, we ran ti springs, etc. we had the heads done with valve angle and guides. I replaced all the lifters and within 3,000 miles I have noticable lifter tap, when I listen to other 993 engines I don't hear this noise. I am driving it now with 0w40. What do you think would be the right one to run? I even considering solids thats how much I want to address this issue.
|  04-01-2007, 07:21 AM |
| Moderator |
			993.105.141.05 is stock 993.105.141.51 is size 1 993.105.141.61 is size 2 Stock intake spring height for an M64/05 - 08 is 36.7 +0.3mm, exhaust is 35.7+0.3mm which version you need depends on the difference your spring height is from stock I don't know the actual length of any of them, You will need to find that out and choose acordingly.
|  04-01-2007, 08:49 AM |
			thanks Bill. I will find out the height of mine and see what this means. Big help, I appreciate it.
|  04-01-2007, 05:13 PM |
| Registered Join Date: Feb 2007
			Could we have more pictures of you car? Exterior shots would also be nice... Are those original Speedline for Porsche wheels? Incredible car and cool color, Bill. | ||
|  05-15-2007, 10:40 PM |
