Manassas, VA
lucittm's Avatar
Question Help Needed - 964 Turbo Reassembly
I hope boeing 717 or one of the other 964 turbo owners can help me here. I am putting my engine back together and I took pictures but one area was covered by a breather hose.
I am trying to figure out the purpose of the 6M x 12 bolt (or if there was a bolt there in the first place) that is threaded into the top of the oil filter housing on the passenger side. I know the other 6M x 12 bolt that is threaded into the engine tin holds the air duct in place.
This is holding up production!!!
Thanks,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 10-07-2008, 07:55 AM
Did you figure this out?
Old 10-22-2008, 09:22 PM
Manassas, VA
lucittm's Avatar
Yes, I did figure it out. I would like to have known where everything goes before I started re-assembly.
So, I started to re-assemble and found out that the 6M x 12 bolt that was threaded into the oil filter bracket connects to nothing. I pulled out the bolt and found another location for it.
Maybe another model uses that threaded hole, mine doesn't.
Thanks,
Mark
Old 10-23-2008, 06:39 AM
