993 engine bits compatible with 964?
A few questions about what 993 engine parts will fit in a 964 motor
1. Will 993 Cams work in a 964 motor? I know the 993 uses hyd. lifters, but could those be used in the 964 cam housing? Is the lift or duration wrong?
2. Will 993 rods work in a 964 motor?
1981 911sc RoW Coupe (forever under 3.6L conversion)
2003 996TT Basalt black
Old 10-21-2008, 01:47 PM
Bill Verburg's Avatar
1) no, the 993 uses a friction lock on the cam nose, 964 and earlier use a positive mechanical lock
2) no, the 993 rods are narrower, 964 uses wider 930 rods
Bill Verburg
Old 10-21-2008, 01:53 PM
DW SD's Avatar
I have 993 heads, intake and exhaust on a 964 bottom end. I use the 964 cam bridges due to use of back dated (solid lifter cams and not hydraulic).
Doug
1971 RSR - interpretation
Old 11-10-2008, 11:28 AM
Some of the earliest '94-built 993s still employed the mechanical lock. I like the fact that mine does.
Andreas
1995 993 Coupe, Polar Silver / Black
2014 Audi A4, Monsoon Gray / Black
2002 Toyota 4Runner, Dorado Gold
2001 Toyota 4Runner, Dorado Gold, 604,XXX 1-owner miles
1998 Toyota 4Runner, Oxidized, 5-speed
Old 11-13-2008, 04:41 PM
Andreas
That's true, the older 911/964 style was used into the '95 gen1 993s
Bill Verburg
Old 11-13-2008, 05:06 PM
930gt-40r's Avatar
I like working with the 993 cam towers more than the 964 ones- I like the fact that the rockershafts have two allens instead of the old style pinch bolt. I also like timing the 993 (stock) better for obvious reasons. Its just easier to work with and takes the brain work out of it.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 11-13-2008, 07:56 PM
If you have the factory tools it's certainly easy to set up the cams on a late 993, however the issue is that the cams don't always stay set up w/ the friction system. It is a sadly common issue.
Bill Verburg
Old 11-14-2008, 04:39 AM
rsrmike's Avatar
I've used the factory tools to time several 993's and always had a funny feeling about it, most times, the proper "shank" bolts wouldn't fit w/ fixture in place, in which case the book said to substitute a standard 6mm bolt??!! It still seemed to have tolerance.
That should be the first thing a 993 guy does in search of more power-check cam timing!
If I recall, some of the 993 turbos left the factory w/ incorrect timing?
Professional Overcomplicator
Old 11-14-2008, 09:26 AM
