Noise when taking a left bend
I own a 1991 Porsche 964 C4 Cabrio and have the following problem.... when I take a turn to the left (also at low speed) I hear a noise which appears to come from the engine compartment, its like a buzzing or groaning noise. When the car (engine) is cold the noise is much louder than when its warm... when the car has been used for a while the noise only appears at high speed corners.
Anybody has an idea where to look?
Thanks, Marco.
Old 03-18-2009, 11:12 AM
kurquhart's Avatar
Power steering? Although that should groan on right turns, too...
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 03-18-2009, 05:10 PM
Chris Wiles's Avatar
Check the Wheel bearings. It has nothing to do with the car running hot or cold, but it sure sounds like a bearing is out on that side. Easy check.
CW
Old 03-19-2009, 09:01 AM
my 89 c4 has a problem too bubles the power streeing fluide still trying to fig it out
Old 03-20-2009, 06:33 PM
Rick Lee's Avatar
Had the same thing after a shop had my engine out. They were a few cups low on ps fluid and that fixed it.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 03-24-2009, 06:31 PM
Send a message via AIM to JCaffarella
Mine used to make a noise only when I'd make left turns. It sounded like the rear tire was rubbing the inside of the wheel well. I topped off the power steering fluid and haven't heard the noise since.
Old 03-25-2009, 07:19 AM
