e p slick's Avatar
code scanner suggestions - 993
Just moved sideways to a 993 so am researching code scanners/capabilities.
Any suggestions or "Stay away froms" ?
EPS - Tucson
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 03-28-2010, 04:43 AM
Don Plumley's Avatar
A basic OBDII scanner (I use an Actron) will read most of the codes you need, reset CEL's and tell you if the readiness indicators (for smog) are set.
If you want to get into airbag or ABS control, then you have to step up to a durametric for the factory PSTII.
Don Plumley
M235i
Old 03-28-2010, 01:51 PM
e p slick's Avatar
EPS
Old 03-28-2010, 02:55 PM
Bill Verburg's Avatar
Durametric is pretty good but not perfect
Bill Verburg
Old 03-28-2010, 06:46 PM
Autobahn Garage
Durametrics is as close to the real Porsche scanner as you can get. Plus they have GREAT customer service and will help you
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 04-14-2010, 12:36 AM
Alps Adventurer
Traveller's Avatar
What year 993.
The 1995 had OBD I with an OBD II connector...at least mine does.
The 1996 and up models as with any make/model car went to OBD II.
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 04-14-2010, 08:56 AM
