can I use a G50/21 with a 996TT engine "bolt on"?
I'am only referring to engine-to-gearbox fitment. since they will sit in mid engine configuration in a tubular chassie. (gearbox flipped). - what clutch/flywheel combo will work ?
Old 08-16-2010, 07:24 AM
Banned
No you can't. It will bolt on to the engine, but the shift controls and attachment mounts are completely different.
Old 08-17-2010, 05:00 PM
Mounts will ofc. be one-off since it's a tube chassie, and shifter will be a wire-shifter conversion or a sequential shifter conv. - so those two factors I got covered. (note gearbox is flipped - and engine sits between so it NEEDS to be wire or robotshifted)
It's the mount to the engine - and what clutch / flywheel to use that the question
but if the gearbox bolts on (as you mentioned) - can I just use 996GT2 or TT clutch/flywheel then straight off then?
Old 08-18-2010, 12:37 AM
Banned
Yes you can, cheers.
Old 08-18-2010, 06:36 AM
