Now in 993 land ...
aigel's Avatar
Spark plugs install - how do you do it?
I have the engine out for my transmission rebuild and refreshing the ignition. How do you all install your plugs?
Dry or anti-seize?
Torque or by feel?
What torque if you use a wrench (30 Nm per factory manual)
Thanks!
George
81 SC (sold)
Old 07-10-2011, 04:21 PM
964TargaC2's Avatar
Since engine is out definitely torque them all
Itas almost impossible to get accurate torque on some of them while engine is in..especially top 6
I use anti seize...some dont, Its probably a 50/50 on that
Old 07-10-2011, 05:55 PM
Anti-seize, and I torque by feel (the anti-seize saves me there!)
LouZ
'90 C2 TIP
'08 Cayman S
Old 07-10-2011, 06:06 PM
Porschedr.'s Avatar
Anti seize and torque with a torque wrench. If you're asking on here, your elbow is not calibrated enough.
Old 07-10-2011, 07:05 PM
Now in 993 land ...
aigel's Avatar
Great input. Thank you. I did 3 today and put the new ones with 28 Nm per Bosch spark plug box instructions. I have a well calibrated elbow, but if I can like to use the torque wrench!
You will read a lot more questions on here soon, please visit and help as you can!
Thanks!
George
81 SC (sold)
Old 07-10-2011, 10:10 PM
The torque values stated by the factory are without anti-seize if my memory serves me right.
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 07-11-2011, 06:06 AM
Now in 993 land ...
aigel's Avatar
James,
I did them dry. Not planning on leaving these in for 100k miles.
George
81 SC (sold)
Old 07-11-2011, 06:40 AM
Torque specifications are for new, clean and dry threads. Add rust, corrosion, oil, anti-seize or a combination of them all and the specs quickly become guidelines. Makes the old elbow and the chrome eyeball pretty accurate!!
Old 07-13-2011, 08:49 AM
Anti-seize, always.
Old 07-14-2011, 07:30 AM
Alps Adventurer
Traveller's Avatar
Anti-seize and 18 lbf.ft. for torque.
The recommended torque for a 14mm spark plug with washer in an aluminium head is 18 to 21.6 lbf.ft. I chose to go with the minimum value since I used an anti-seize compound on the threads. Spark plug torque specs are for dry threads.
As for the anti-seize, I use a high temperature copper compound. There are various types available. The one I now use has a far higher temperature rating.
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 07-15-2011, 04:17 AM
