Is 993 turbo and an 993 same platform
New to the porsche scene so I will need your knowledge from the Guru's.
I have an 993 turbo with front end damage which will need replacing,
can anyone tell me if they know or have scene this performed or what are my possibilities to replace front clip.
need your help!!!
Old 01-16-2012, 08:19 PM
Bill Verburg's Avatar
need your help!!!
993C4S, C2S & turbo all share the same front end pieces including chassis and suspension arms(C2S has different inner longitudinal pieces) & finish sheet metal/plastic pieces
RS uses the same chassis and brake pieces
C2 & C2S use the same chassis pieces & suspension arms but different brake m/c mount which is on the inner longitudinal suspension piece
Bill Verburg
Old 01-17-2012, 10:49 AM
Bill
Thankyou!
This should help me greatly in search of front end.
any more info I should know about these cars would help.
Thanks.
Old 01-17-2012, 05:16 PM
So can a 993 C2 suspension be used on a 993 turbo or viceversa? I noticed some vendors would sell a new suspension labeled for all 993 setups while others will only list for C4S and turbo only.
Cheers
Old 01-28-2012, 09:43 PM
Cheers
Yes, The arms and shocks can be switched around freely though attention should be paid to spring rates which are somewhat different among the various models and option packages
Bill Verburg
Old 01-29-2012, 02:43 PM
