Science is NOT optional
WOT: how does one confirm wide open throttle?
Where do you look to see the butterfly position to check? I've searched a bit and don't see it previously outlined. My Webers are easy, just look down the venturis and adjust linkage until vertical.
Any good links out there?
PCA member since 1993 |
From what I understand, WOT ignition timing and fuel tables are activated once a little microswitch on the throttle body is activated. To make sure you are indeed hitting WOT, have a friend mash the gas and check to make sure it clicks when the pedal almost reaches the floor. Might also be a good time to clean that area and make sure nothing is gummed up and sticking.
993 Speedster: Are you from south of the Mason Dixon line?
There's no butterfly that's easily visible. Look at the linkage on the T.B. and you will see a black microswitch at the lower end (electrical plug will be attached to it). From the engine bay (with the engine OFF), pull down on the linkage and see if and when it makes contact, it is supposed to be at 78% open.
To verify, pull the plug on the microswitch and hook up an Ohm meter, and see that it is actually closing the contact on actuation. If the switch does not make contact, you will have to adjust the throttle cable at the pedal and/or in front of the tranny by pulling up the slack a bit.
LouZ '90 C2 TIP '08 Cayman S |
There is a switch on the side there and I seem to be activating on WOT but I should do a continuity check. Aren't there 3 blades there on the connector? Can someone say which is which?
Here's the wiring diagram of the Idle and WOT switches.
Does a Hammer/ scantool interrogate the wide open throttle switch?
the 964 system is somewhat different but I'd guess that it reads similarly
lol
1996 Carrera Guards Red over Grey - Back in the 993 world!! 2009 2S Nordic Gold over Cocoa, my sweeties car (Chairman Meow) 2024 Audi A4 Allroad Navarra Blue over Grey 2010 Audi A6 Avant Grey over Grey - Supercharged! Lottsa "steel is real" bicycles |
A Hammer (kts300) does as well as the scantool.
1990 964 C4 Cab 2008 Range Rover Sport (daily driver) |
However, you state "pinned to the floor", as I posted earlier, it should kick in around 78%. Slowly depress the go-pedal, and watch when the scantool's WOT switches, then make sure that there is additional travel before it hits the floor.
Good idea. When the snow melts I'll see where the WOT switch activates, hopefully this week. How do you interpret the MAF sensor and the O2 sensor readings here? I'm assuming the O2 sensor reading is meaningless as the engine is off but the MAF sensor should still be accurate representing a voltage from the MAF dependent on flap position, but I really don't know that. And technically, being a 964, it's not a MAF but and AFM, correct? Anyway, an MAF voltage of .25 at WOT is what is reported here. What are normal MAF readings for a 964? Do I check MAF voltage at various throttle positions or just remove the AFM, clean it, and reinstall?
PCA member since 1993 Last edited by rbogh901; 02-02-2013 at 06:47 PM.. |
In the name of furthering this topic should anyone in the future ever want to know, I did run scantool again this afternoon. Indeed, as per LouZ, the WOT switch activates before the throttle is fully pinned to the floor. I would estimate that it does so around 75-80% wide open, as advertised.
Thread Tools | |
Rate This Thread | |
