RSA lowering
I have a 93 RSA and just had a set of H&R sport springs installed the shop set the ride height at 138mm front and 245mm rear it still looks to high ,there is 1 1/2inch gap from top of tire to fender on front and 1inch on rear, any help on ride height specs ,I want the lowest ride height without damaging anything
Old 12-23-2012, 12:48 PM
Bill Verburg's Avatar
It appears that you are just ~13mm higher that RS in frnt and 22mm higher in bac
and 964 measureing points
What wheels and tires?
Why not go to RS height if you have 225/45 and 255/40 x17 rears(or similar)
Bill Verburg
Old 12-23-2012, 02:26 PM
Thanks for the info and specs , I will have them set it up at rs euro spec
Old 12-23-2012, 04:33 PM
I do have factory cup 1 wheels and tires
Old 12-23-2012, 04:40 PM
