Bill Verburg's Avatar
Originally Posted by porterdog View Post
Hate to argue with a guy who both knows a ton and is an extremely valuable forum resource, but Bill, that comment is total bulls ****e.
If it is then I'm not the only one w/ that opinion
964 G64
Bill Verburg
Old 01-30-2013, 08:03 AM
If the sole basis for your bias is that it's hard to convert to RWD, I believe I already conceded that point, having labeled that option a "fool's errand."
What else you got- the one or two guys whose transmissions failed in an expensive way? Definitely a drag, but if these things were popping all over the place we'd have heard about it here.
'90C4
Old 01-30-2013, 08:36 AM
Originally Posted by GBX View Post
Thanks. I'm leaning towards AWD b/c of the advantage in daily driving. Any major differences in MY's? Also, any options a must to look for? Was an LSD an option on the C4 or only C2?
No major changes in the AWD system within the 964 series. Major change in rear suspension mounting at the end of 1990; there are fewer options for the early cars.
There were some other minor tweaks- the manual spoiler control was moved to the center console (from the engine department) in 1990 I think, but that's about it.
The C4 has an early-version stability control called PDAS that will progressively stiffen and lock the center and rear differentials if wheelspin or yaw is sensed, so there was no LSD option available.
Find one you like, spend the money on a qualified inspection, then evaluate the price-point against the greater market.
'90C4
Old 01-30-2013, 08:41 AM
GBX GBX is offline
GBX's Avatar
I spoke with TRE on using a 964 for the conversion and they quoted around $100k. Supposed to be a lot of plumbing that has to be moved around and reconfigured since longhood front and rear bumpers expose a lot. They have me looking for a 3.2 now but would much rather use a 964 base. Thoughts?
Old 02-05-2013, 08:22 AM
Doug&Julie's Avatar
Where are you located? G50 model 3.2 Carreras are very drivable cars and easy to use on a regular basis. But if you're anywhere that gets extreme weather, you might like the ABS and better A/C available on the 964. That's not to say that the A/C on a 3.2 Carrera couldn't be made much better, but you'll never get ABS on it.
A G50 Carrera backdate is on my "next" list...FWIW. Of course, that won't be for a while, sadly.
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 02-05-2013, 09:52 AM
GBX GBX is offline
GBX's Avatar
I'm in NY. I like the idea of ABS and airbags too but maybe I'm asking for too much . What can be done on a 3.2 to make the A/C better?
Actually thinking about using a targa. Could be a little more unique and a fun summer driver.
Old 02-05-2013, 04:59 PM
Doug&Julie's Avatar
There are aftermarket A/C systems that improve early 911 A/C. They're not cheap, but in the grand balance, if a 3.2 Carrera is a cheaper backdate than a 964, it may balance out.
Anyway, I think Paul K used a good one here: I'm back! With an '83 Coupe...
My (current) dream garage is a hot rod longhood coupe and a backdated G50 Targa, complete with silver Targa bar and chrome accents. I'm thinking about turning my 912E into that coupe, and buying the Targa next. I agree, I think it would be a really cool car, and not a lot of people have done / are doing it. Do it!
But like I said before, for me...big dreams...long way away...
Doug
Old 02-06-2013, 04:07 PM
A Norwegian transformation - How about that ?
Porsche 911 (964) Carrera 2 "Retro" RSR 1990, 2 026
Old 02-08-2013, 12:42 PM
