si Banker's Avatar
964 Engine Clading
My 964 has the engine cladding removed off the bottom of the motor. My question is concerning the the foil covered panels that surround the engine. When the the bottom panel is removed it makes the foil panels useless.
Do most 964 owners remove them?
Has anyone noticed a lower engine temp?
Is there aa increase in noise with the panels off?
1987 911 Coupe
Triumph Trident Track Master
History is the lie we all agree to..........
Old 02-20-2013, 06:06 PM
I run the side foil panels without the engine bottom covering. I believe the side panels help the heat away from the valve covers and chain covers.
1990 964 C4 Cab
2008 Range Rover Sport (daily driver)
Old 02-20-2013, 06:14 PM
+1
The side panels also keep grime that is tossed up from the rear tires from making a mess of the lower valve covers/plug wires.
Old 02-20-2013, 10:09 PM
These panels were missing on my car when I purchased it. Are they still available?
Old 02-22-2013, 10:36 AM
I Fort Worth you shouldn't use the bottom cladding. You need the air.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 02-26-2013, 09:49 PM
