Sugar Scoops Rule :)
964 Tiptronic Throttle Position Sensor set up
I've searched high and low, here on Pelican and elsewhere, and can't find the set up values / procedure for the TPS anywhere?
Can anyone help or point me to a resource where I can find them? Car is a 92 Tiptronic, stock intake system.
Dave _______________________________________________ '76 911S Targa '62 VW Type 1 Sunroof '73 914 2.0 (1st Porsche, gone long ago but not forgotton) |
interesting.. i have a 90 tip... following this thread to see what unfolds.
What are you trying to do? |
Helping a buddy troubleshoot - the car drops RPM when coming to a stop, and need to set up the TPS after removing the throttle body to clean it.
I had a similar issue with mine...
Turned out that it was a bit low on transmission fluid... apparently when this tiptronics are low, they are prone to stalling... I don't understand it, but it was something to do with the torque converter not letting go if the level is too low... Might be worth a look? |
Yeah, thanks, fluid level is ok, along with a long list of other potential causes.
There sure isn't as much information available on these cars as the earlier 911's, especially the Tiptronics!
