How does this trim hold in place?
Hi,
Can someone tell me how this black pastic trim hold in place? Is it screwed or clipped? How does it attach to the body or the abs pump? Thanks!
Ari
In my car, the cover in that location has a very obvious screw. It's a long, skinny screw with a black plastic head that you can usually turn by hand but may also be turned with a sufficiently wide flat-head screwdriver. I hope that helps.
Thanks! I think I found it. It's 2 push buttons (part # 99904901840).
What model 964? RS?
What is the water bottle on the left (intensive washer system?) I have never seen the brake system set up this way before. I see it has the electro hydraulic brakes but the canister is in a different location and the cover you referenced is different than any I have seen before.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
Your question has been answered. I'm just enjoying that super clean trunk!
My first love - 1993 964 C2 Manual Coupe My second love - 2021 Macan GTS |
Makes sense now. Very nice and clean
It was owned by a friend and was the cleanest Cup I had ever seen. It was a guest racer car and only lightly used a few times in Europe and then for a few PCA races over here. I'm kicking myself for not buying it when he sold it. The place that bought it doubled the asking price and flipped it for an unknown sum.
