Engine install question
About to reinstall my engine 964 after replacing all seals and head studs. I also rebuilt the cv with new boots. Would one recommend installing engine then cv axles or cv axles first??? I believe I removed cv axles prior to dropping engine but cannot remember. What's easier?
Old 07-08-2015, 10:07 PM
I installed new axles with engine in the car without a clearance issue on my 993. But installing the engine with axles in did add a bit of a clearance issue. If they were out with the engine. I would opt to install them after engine was in place.
Old 07-09-2015, 07:14 AM
Agree; it's easy to r&r them with the engine in the car. I wouldn't even try the other way.
'90C4
Old 07-09-2015, 06:39 PM
Either way should be fine. I have never removed the axles when I have removed the engine. Just secured them out of the way.
1990 964 C4 Cab
2008 Range Rover Sport (daily driver)
Old 07-10-2015, 06:30 PM
Newsboy's Avatar
You can do it with the axles attached. Just go slow, and make sure everything clears.
Old 07-13-2015, 03:03 AM
efhughes3's Avatar
Yes, you can do it either way. But since they are out now, the wise choice would be to install the motor first.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 07-24-2015, 06:56 PM
