jamesjedi's Avatar
Inspecting Engine Internals - without splitting the case
How much of the engine internals can be inspected without splitting the case? What can be checked to determine if it is within spec?
I don't want to start my 964 engine without checking as much as I can.
Thanks for any help.
Old 02-28-2017, 11:41 AM
Newsboy's Avatar
Did you just buy the car? Do you mean starting the car, or starting a rebuild Need more specifics.
Old 03-01-2017, 02:07 AM
jamesjedi's Avatar
Engine is on an engine stand.
I have found an issue with the exhaust valves, what can be checked if I remove the P and C's?
Old 03-01-2017, 03:02 AM
JJK78-951's Avatar
Pretty much everything but the bearings. Once you have the heads off you can see quite a bit
John~
2003 996 Turbo... 128K Daily-ish
2000 Accord V6... 275K - 65K motor/trans now given new life!
Old 03-01-2017, 08:59 AM
jamesjedi's Avatar
Thanks, can you measure the crank?
Old 03-01-2017, 11:05 AM
nickd's Avatar
You can't measure the crank without splitting the case. How many miles? The bottom end is pretty robust.
1991 964 C4 Cabriolet - drop-top pylon destroyer
Old 03-01-2017, 03:01 PM
jamesjedi's Avatar
Low miles - former race motor. I have it on an engine stand and need to have some cylinder head work completed, or replaced.
Thanks for the input.
Old 03-01-2017, 04:42 PM
