964 Rear Caliper question
I went to order new pads recently and only just learned that having the early 964, means that front and rear pads are different... but that on a later 964, they utilise the same pads front and rear.
Does anyone know if the rear calipers from a later 964, are a direct bolt in for my early 964?
Sorry if this is a repeat question, but after a half hour of searching couldn't quite find what I was after... (getting too old I guess)
Old 05-04-2017, 02:39 PM
Bill Verburg's Avatar
964 came w/ 3 different rear calipers
v1 2 44mm pistons
v2 4 28/30 pistons, these use the same pads as the front which is the same as 930
v3 4 30/34 pistons, these came on RS and t. and use the same pads as v2
the 4 piston rears( except the ones from a turbo) are a bolt on w/ the stock rotors.
The down side of this is the f/r bias deteriorates, so a less aggressive or no p/v would be used
Bill Verburg
Old 05-04-2017, 04:31 PM
OK, so V2 is what I need.
Awesome..now the hunt begins.
Old 05-05-2017, 02:17 AM
You'll get better bias if you can find 964RS rears, regular 993 rears are the same as the 964RS rears. All use the same pads as the fronts
Here is what you have
Here is 964 v2
here is what you have & v2
early RS looks the same as 964 v2, late 964RS looks the same as regular 993 rear
early 964RS on left & late 964RS/993 on right
Bill Verburg
Old 05-05-2017, 12:13 PM
very helpful...
so something like this listing should be good for my early 964?
Straight bolt in and using same pads as front right?
Porsche 993 911 Carrera 2 rear brake calipers Brembos | eBay
Old 05-05-2017, 12:26 PM
very helpful...
yep
w/ the 993 rears and stock fronts your bias goes to 1.547, ideal is a little lower ~1.491 but better than what you have now 1.643 or would have w/ v2 964 1.692
Bill Verburg
Old 05-05-2017, 03:11 PM
Thanks Bill.
I have ordered a set from LA Dismantlers..
Should be here in a couple weeks hopefully.
Mike
Old 05-06-2017, 08:29 AM
Calipers are here... just have to clean and inspect to see if they need new seals and/or pistons... To be sure, these 993 rear calipers have a 30mm and a 34mm piston right?
Old 05-31-2017, 02:03 PM
Yes, they also use the same pad as the 064 4 piston rears and 964 front
Bill Verburg
Old 05-31-2017, 03:43 PM
Bill, thanks to you I now have a set of 993 rear calipers in my 964. Perfect fit and using the same pads as the front. Thank you.
Were the 993 front calipers an upgrade over 964?
Here are some photos showing the comparison between my old rear calipers and the new ones.
Old 06-29-2017, 01:05 PM
yes, but it's more involved to fit them
to fit 993 front calipers to a 964
first you need to decide which wheel carriers you will use
964 steel wheel carrier & obtain a caliper adapter from Rennline or VCI or such uses 928S4 32x304 rotor
or
964t/RS steel wheel carrier, advantage no caliper adapter and use 928 S4 solid 32x304 rotors or
993 aluminum wheel carrier, advantage no caliper adapter, lighter and uses 993 32x304 drilled rotors or
993RS alumium wheel carrier, advantage no caliper adapter, lighter, uses 993 drilled 32x304 rotors and has bump steer compensation for very low cars
+you will want to change the m/c and booster assembly to 993
964 to 993
ypu will need
m/c 993.355.910.00
vac can 993.355.023.10
gasket 993.355.301.00
support 993.355.163.03
+ 2x 10mm to 12mm brake line adapters, or have some custom lines made up
BMW part number is 34-32-6-752-405.
Bill Verburg
Old 06-29-2017, 01:32 PM
