ANOTHER 964 Aircon Question
So, I just had a specialist replace my compressor, exp valve, drier, pressure switch and evaporator.
Aircon is nice and cold. However, the volume of air that comes out of the left hand side vents, is no where as strong as the right side blower vents. What could cause this? |
If I had to make a guess I would suggest getting the driver side blower motor exchanged or renewed .
There is a squirrel cage blower behind the interior micro filter that pushes cold condensed air into the cabin , it's likely failing or on its way out.. Bert
GT2 RS 3.2 RSCS 3.8 R 2.5 Twin Plug |
Plus 1 on that, if your talking about a 993 other wise the 964 has no filters.
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
I think another possible culprit is mixing servos weak or inop.
'90C4 |
I also need my AC redone just like yours, how much did it all cost?
I have played with the airflow a bit; it appears as if the 2 outside vents, closest to the doors are blowing at the same amount of force. However, the 2 centre vents, even though they are right next to each other, blow at very different force... If it blows nice and cold all through the summer and beyond, then I will be happy (ish). |
