Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
996 turbo mezger engine build specs?
Hi All,
Hope you're well. I'm taking on the rebuild of a 996 Turbo engine (with my professional engine builder friend...i'm not a wizard!), but I've drawn a blank on the build specs....Looks like if you take your motor to Porsche they give you a new long block, so even in the 2000 page technical document we have, it doesn't have specs...
Specifically we're looking for:
- What are the running clearances on the valves – exh / in
- What is the piston to bore clearance?
- What are the specs for the cam / crank / IMS journals, running clearances and thrusts?
- What are follower wear limits / running clearances?
- What are the oil pump clearances?
I've done a forum search and can't find anything either....
Thanks in advance for any help you can give or anyone who'd know we can get in touch with.
Rob.
Old 06-03-2020, 10:36 AM
If you are going to increase the boost pressure you will need to deviate from Porsche clearance spec's
Old 06-03-2020, 10:55 AM
JFP in PA's Avatar
Originally Posted by racer86 View Post
Hi All,
Rob.
Porsche never published this information.
Accrochez-vous bien de vos rêves..........."
Old 06-04-2020, 06:55 AM
