Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
bcr4d's Avatar
replacing spark plugs
My question is how difficult is it to replace spark plugs on a 2000 996. Everything else is pretty cut and dry. Is it a DIY, or is it better to take to someone. It looks pretty cramped in there. thanks
Billy Crawford
Old 04-06-2007, 08:44 AM
JakeTheSnake's Avatar
I would have someone ride shot-gun if you haven't done it before, just for safety's sake.
I wouldn't call it a difficult job but you could use the helpful tips if you get stuck. The first time around you should expect a 4-6 hours on this job. Once you have the hang of it you can do it in around 4....
Jake,
Big Jake
Porsche 996
I've been known to take apart a 996 or two.
Old 04-07-2007, 07:36 PM
AFJuvat's Avatar
DIY - you will need a jack, some jack stands, a 5/8ths spark plug socket on a 3 inch extension, a 10mm wrench and fairly flexible arms.
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 04-07-2007, 09:41 PM
Small hands and fingers would also help...
Big Jake
Porsche 996
Old 04-09-2007, 11:28 AM
bcr4d's Avatar
reply
thanks for your replys. 4 hours seems lile a long time to replace 6 spark plugs. Is there something I'm overlooking.
Billy Crawford
Old 04-09-2007, 11:46 AM
Re: reply
Nope, just look at the area you're woking on ......
You'll see what I mean.... The record here is 2-hours, but I estimate the 4 for those who are not HighSpeed.....
Jake
Big Jake
Porsche 996
Old 04-17-2007, 11:07 AM
AFJuvat's Avatar
45 minutes here....
Of course, I did do this for a living....
Old 04-17-2007, 11:56 AM
slohja's Avatar
So do I have to take off the wheels , drop the engine? Whats the best procedure for this to make it 6 hours instead of a whole weekend?
I bought everything I need for my 60k maintenance from this site, now I need to install it.
...also, the spark plugs have 4 points on them, I am guessing they are pre gapped?
- Slobo
1999 Porsche 911 Carrera (996)
Old 04-19-2007, 12:20 PM
AFJuvat's Avatar
Yes, they are pre gapped.
Lord no, you do not need to drop the engine. Just get the back of the car on stands.
Old 04-19-2007, 05:48 PM
I'm 1/2 way in a 2002 and about 1 1/2 hours in 100 degree heat. Damn tight spots. I've had to use torx sockets, 1/4 drive and my 1/2 drive w/a 3/8 adaptor for the extra reach.
Would you guys re-install the heat/weather shield?
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 07-07-2010, 02:26 PM
The pass side rearest plus is a complete PITA. Next time I'm pulling the mufflers and I would strongly reccommend that to anyone wanting to do this.
Old 07-08-2010, 10:40 AM
2 hours here but i have Fabspeed muffler by-pass pipes.
I would also recommend replacing the spark plug connectors and inspect the coils for cracks. If you have oil leaking, then also replace the spark plug tubes
Alex
Old 07-08-2010, 10:59 AM
if you think the spk plugs are a pain in the butt, wait till you change the fuel filter, they couldnt think of a more stupid place to put it .......
Old 07-09-2010, 07:54 AM
Stupid. My car doesn't even have a replacable filter!
Old 07-09-2010, 08:50 AM
Filter
On the 2001 911 3.4 I converted to all electric, the filter was on the bottom of the car, under the plastic panels in the center of the car, under the water pipes that go from the radiators to the engine, I had to remove the pipes, all of them, to get to it to remove it. since it wasn't using any gas or water it was senseless to keep them in place ..
Old 07-09-2010, 09:29 AM
Anyone else think that pulling the mufflers is the way to go? Also, I've received mixed responces on whether or not to leave the guards in place due to the heat concern for the coils. What are the opinions here?
Old 07-10-2010, 07:58 AM
I just replaced my spark plugs (at 40K miles) and found it a much easier job after the mufflers were removed. I doubt if I could have completed the job on all cylinders with them in place.
I think it would be a big mistake to not replace the heat guards over the coilpacks. There must be a significant amount of heat radiated from the exhaust system onto this area and there are many reports of coils that have failed and found to be cracked, even when the heat guards were in place. There is little doubt in my mind that heat on these coilpacks is a very bad thing.
2015 Porsche Macan S, Dark Blue Metallic
2011 BMW 328xi, Crimson Red
Old 07-11-2010, 09:10 AM
The issue is radiant heat vs airflow. There are 2 camps on this. TPC and EBS representatives are 2 of the groups who have given me the idea to pull them. ITO the hold more heat than they keep away. I reinstalled but this discussion seems like a Ducati (or air-cooled 911) oil discussion. Everyone has their opinion.
Old 07-11-2010, 11:55 AM
In the specific case of the water-cooled M96 engine, I would think that airflow would be less important for heat dissipation from the area around the sparkplugs than would be retention by the black coilpacks of excessive heat radiated toward the area from the exhaust system if the guards are missing. The guards are not tight up against the coilpacks when installed and there is a bit of clearance for air circulation.
I cleaned and polished my guards before I re-installed them so they would be better heat reflectors.
Old 07-11-2010, 01:02 PM
