Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Scan Tool Question
Harbor Freight has a great buy on an OBD II scan tool. I know it won't read the codes on my 996 turbo, but will it reset a "check engine" light warning? I have an occasional "check engine light" problem caused by a gas cap seal issue, even though I bought a new gas cap. It rarely happens, but I've learned to reset the code by disconnecting the battery. I'd rather use a scanner. Does anyone know whether the OBD II will do what I want? Thanks. Komac
Old 04-01-2015, 09:08 AM
JFP in PA's Avatar
It will address some codes on a Porsche (those commonly called Global OBD II codes), but will not address many codes like air bags, PSM, ABS, and other systems. For that, you need a Porsche specific scan tool.
Accrochez-vous bien de vos rêves..........."
Old 04-01-2015, 09:56 AM
Thanks, JFP. Will the scanner clear the check engine light alert? That is the primary reason I'd like to buy it, Thanks. Komac
Old 04-01-2015, 01:54 PM
JFP in PA's Avatar
A Porsche specific tool (Durametric, PST II, PIWIS) would be able to address anything on the car, other tools may or may not be able to, depending upon what is causing the codes.
Old 04-01-2015, 03:18 PM
one of gods prototypes
bell's Avatar
Why not just have the tank vent system diagnosed and fixed?
Brought to you by Carl's Jr.
Old 04-01-2015, 06:59 PM
Jeff Alton's Avatar
^^^^ What Bell said.
www.turn3autosport.com
Old 04-04-2015, 08:43 PM
Broke
Westy's Avatar
I'm keeping notes for when I start shopping for a 996. Which of these gizmos is best? I see the Porsche Durametric Scanner on Amazon for 175 bucks.
Beer is proof that God loves us and wants us to be happy. B. Franklin
93 968 Cab
81 SC Targa (Princess) Now Residing in Denmark
1973 RS Z28 Vash will never own it!
Old 04-07-2015, 07:59 AM
JFP in PA's Avatar
Depends upon how you define "best"; a used PST II (which is already out of date) will set you back a couple grand. A real PIWIS cannot be purchased, only leased (yes, I know you see them for sale all the time on the web, but they are definitely not the real item), and the current lease rate opens at just under $20K for the first year. The Durametric system is about 75-85% or so as capable as the PIWIS, and cost less than $300 with unlimited updates.
Old 04-07-2015, 11:36 AM
Broke
Westy's Avatar
Yeah....don't think I would be leasing something. Thanx.
93 968 Cab
Old 04-07-2015, 11:41 AM
