Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Driving member
jester911's Avatar
Helmet question
I have a question about track helmets. Are they different from motorcycle helmets?
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 01-21-2004, 01:58 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
I had the same question this weekend when I went helmet shopping/fitting at OG Racing.
Apparently motorcycle helmets are designed to displace/absorb energy from one sudden impact where SA (car) helmets are designed to protect from multiple impacts.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 01-21-2004, 02:03 PM
addictionMS's Avatar
nomex liner as well in car helmets, it would have to be pretty wild for a motorcyclist to have a fire engulf their head
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 01-21-2004, 02:40 PM
DanS911's Avatar
MY understanding is that there is only the fire resistance difference in the two. I have never heard about the impact thing.
Dan
'86 911 Targa Driver
'76 911 Targa 3.0 Track Toy
46mm PMOs, 10.5/1 J&E,Web Cams, Wide Body fenders, 23mm and 30mm Hollow T-Bars, 930 Sway bars, Bilstein Sport Shocks, Plastic Bushings (too damn squeeky)
Old 01-21-2004, 06:43 PM
Send a message via AIM to ajackson
I think that the fire resistance difference is correct. There are several helmets that come in two certs, M and SA and the SA one is just fireproof.
Alan Jackson
77 911S 3.2
Old 01-21-2004, 07:03 PM
jyl jyl is online now
jyl's Avatar
Here's the SA2000 standard. http://www.smf.org/standards/sa20std.html
This is the "repeated impact" part:
The capacity for impact protection is determined by direct measurement of the shock delivered through the helmet to a headform when the helmeted headform is dropped in a specified manner onto any of three unyielding anvils. A fourth anvil is used to test impact protection for repeated strikes against a roll cage assembly.
And something about resisting exploding engines:
The helmet must also resist penetration by projectiles such as parts of exploding engines or other damaged mechanical assemblies. This capacity is tested by placing the helmet on a headform and dropping a metal cone of specified mass and geometry onto the shell. The tip of this cone must not penetrate to the headform
And the fire resistance part:
Since race drivers are frequently unable to escape quickly from accident involved vehicles, their helmets must also provide some measure of protection against fire. Exposed helmet components, whether internal or external must be flame resistant. They must not be combustible and when exposed to high temperatures, must self extinguish when the heat load is removed.
Helmet components are tested separately for flame resistance by exposing them to a direct propane flame of a specified temperature for specified time periods. When the flame is withdrawn, each of these components must self extinguish within a specified time limit. Furthermore, when the helmet shell is tested, the temperature of the padding or lining materials within the helmet that would presumably touch the wearer's head must not exceed 70C.
The chin strap must also be flame resistant. The chin strap will be tested similarly to other helmet components. It must not melt and must self extinguish within the allowed time.
Makes you not want to participate in any activity where you'd need a SA2000 helmet, doesn't it? I'm not letting my wife see this.
Old 01-21-2004, 08:10 PM
DanS911's Avatar
Great stuff John. So the repeated impact clause is more about banging on a roll bar that "more than one incedent" impact.
I think the fireproffing info was the most frightning. The're talking about the paint and the chin strap as well as the padding.
Dan
Old 01-22-2004, 10:02 AM
thanks for the details, I learned something today....
Jim
Jim Hamilton
Old 01-22-2004, 10:55 AM
Irrationally exuberant
ChrisBennet's Avatar
While the impact tests for the SA and M helmets are different, I wonder if the helmets themselves are different except for the fire resistance.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-23-2004, 10:36 AM
Danskman's Avatar
You will also find that the M helmets usually have a larger eye opening (laterally).
Mike
'80 911SC Weissach Edition
'87 325is
'02 K1200RS
Old 01-23-2004, 11:44 AM
Brother's Avatar
So what do most clubs/tracks require? SA or M?
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 05-14-2005, 02:29 PM
jacko241's Avatar
I know SCCA requires SA certification. SA, by the way, stands for "special application".
Joe
996 GT3 RSR
Old 05-14-2005, 02:59 PM
Administrator
Jack Olsen's Avatar
In my Simpson model, there is no difference at all between the M and SA version, other than the Nomex lining. I know this because I was sent an incorrectly labeled helmet, and Simpson 'serviced' it by replacing the lining with the Nomex version and re-labeling it as SA approved (this, in spite of the fact that it already had the Nomex lining when I sent it in).
That isn't to say the testing isn't different, obviously. But I think the manufacturers probably reduce their overall costs by making one shell that meets both standards, rather than producing the tooling for two different models.
Old 05-14-2005, 03:41 PM
Brother's Avatar
You're probably right Jack.
I was reading through Saferacer.com and learned all about it. For SA it just has to be fire retardent all over - including paint and stickers.
Paul
1972 914 - Sold
Old 05-14-2005, 04:24 PM
jluetjen's Avatar
Definitely. No matter which helmet your talking about (Motorcycle or Autoracing), they are single use items. One hit or accident and you should scrap them and/or return them to the Manufacturer to be checked. This is because part of their design is that the shell is pre-stressed so that it "pops" upon impact to disipate the energy of the impact. Once it "pops", it's junk.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 05-15-2005, 12:45 PM
