Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
}{arlequin's Avatar
window net WITHOUT welding?
are there any mounting kits out there that allow the install but without resorting to welding the tabs in place?
thanks.
dave
1973,5: one two thweeee! two more
no.don't.stop.
Old 12-28-2005, 08:33 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
jluetjen's Avatar
There are some nets that wrap around the cage. You'll still need a couple of tabs for where the net opens. I have seen people strap these tabs to the cage or rivet them to the cage. The other option is to use through-bolts, but these need to be sized exactly to the hole. Even then I suspect that they weaken the cage. Other then that your options are limited.
Be sure to consult the rules or check with a tech inspector of the group that you run with on track to see what they'll accept. I'd hate to drill holes in a cage only to learn that the work.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 12-28-2005, 10:57 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
911scmedic's Avatar
Window net
Check out the Schroth window nets...two sizes and attach to the cage with hose clamps. It has a seatbelt type release.
Good luck!
Doug
Old 12-29-2005, 02:38 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Away from Dixie
Capt. Carrera's Avatar
Why do you not want to weld tabs to the cage?
Rob in Camden, SC - '88 Carrera.
Track junkie.
Carolina Motorsports Park, Turn One Track Events, Carolinas PCA, NASA SE
Old 12-29-2005, 03:04 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
}{arlequin's Avatar
Thanks guys. Didn't know Schroth made nets as well. Will check it out.
Rob,
This is still a daily driver (mostly) and it's already a big enough pain to climb over the door bars to get in. Last thing I want to add is more protrusions to climb over. I'll probably do no more than two club races per year and just need the net to pass tech. But there will be 360 days left in the year where they will become a pain hence my aversion to a permanent mounting.
dave
no.don't.stop.
Old 12-29-2005, 03:12 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Super Moderator
cstreit's Avatar
Dave,
I attached mine at the bottom with tabs, but they stick out sideways so they don't get in the way, then the top is looped over the cage with aircraft cable...
I did this so no tab would catch my suit if I needed to make a quick exit...
Chris Streit
NASA GTS series Director - Midwest
Partner - ProRaceSupply Motorsports Commerce
Owner of MotoDelta Motorsports and AlconKits.com
2001 GT3 Cup - "Pepin"
1996 993 RS Replica"Polly"
1970 911 NASA GTS4 - PCA GT3 class "Phoebe" FOR SALE
1997 Ducati 748 Monoposto "Daphne"
1971 Norton 750 Commando
Old 12-29-2005, 03:21 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
jhora's Avatar
Dave,
Here is an alternative and it is PCA club legal.
http://www.force5.net/index.html
It works very well for a dual purpose 911 and when not needed you remove and have a clean stock door.
John
Old 12-29-2005, 07:26 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
armandodiaz's Avatar
Dave:
I have one from AutoPower that camps on still new and I believe still in the box. I'll sell it to you cheap, if your interested? Here's some info on it:
http://www.ioportracing.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=AWNIK&Category_Code=WN
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 12-30-2005, 05:26 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
chrisp's Avatar
Keep in mind the reason for the net. You want to keep body parts as far away from any external impact as possible. If you smack a wall sideways you don't your helmet smacking the wall. The further in board the net the better. Mount it inside the cage if you can.
'83 SC
Old 12-30-2005, 09:44 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
What about helmet and arm restraints so you can forgo window netting?
I use my own variant of the IOPort setup and it works fine.
Old 12-31-2005, 04:54 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
}{arlequin's Avatar
theoretically yes, but the rulebook says "net" so i gotta use a net
also, other than a halo, i'm not aware whether any helmet restraints prevent side to side movement
dave
no.don't.stop.
Old 12-31-2005, 05:40 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
Look at some sprint car setup. They use these triangular, pennant-like, "nets". I think I saw one on Plavan's pictures. Let me see...
This shows it on the inside of the car. One can be mounted similarly on the door side:
http://www.theplavans.com/racing/carpics/10-18-04/images/DSC02569_JPG.jpg
BUT, the rules is the rules and if this isn't allowed, no go. I'd ask though...
Old 12-31-2005, 06:10 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Junior Member
Force 5 window net
A local club member and Industrial Design Enigneer designed a net that fits into the window channel of your door. It's called Force 5 and is PCA club race approved. See http://www.paragon-products.com/product_p/f5_911driver.htm
Kurt
71 911T sold for pieces
88 Targa
Old 02-11-2006, 04:45 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
Cory M's Avatar
I've got one that attaches to the window frame, I don't remember the manufacturer but I'm pretty sure it was purchased from the Racers Group. It was a lot cheaper than the Force 5 one. This is okay for a street car with a rollbar but I think one that attaches to the cage is much better.
Old 02-13-2006, 09:40 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
