Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
difference btwn. motorcycle and car helmet
I know for AX/TT you ar required to use a SNELL 95 or new rated helmet.
What is the difference between a friends motocross helmet and mine? He wants to use his full faced motorcycle helmet during a AX??
Ray Crawford
1972 911 S Targa
1973 E Flairs n Chairs
Old 04-10-2007, 11:00 AM
Bandwidth AbUser
Jim Richards's Avatar
See: What are the differences between the SA, M and K standards?
http://www.smf.org/faqs.html#7
BTW, the PCA regions whose DE's I attend require Snell 2000 or newer, and some will not accept anything other than SA helmets.
Jim R.
Old 04-10-2007, 11:05 AM
Driving member
jester911's Avatar
The main difference is the SA type helmet has fire retardant material in the lining and the M type doesn't.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 04-10-2007, 11:27 AM
Administrator
Jack Olsen's Avatar
SA helmets have fireproof linings and are tested for repeated (versus single) impacts. Usually, the shells are actually the same for both types, but the lining is Nomex on an SA helmet.
Old 04-10-2007, 11:29 AM
kurquhart's Avatar
This is the current Zone 8 PCA rule:
Approved helmets are required to be worn at driving events. The following helmets are approved for Autocross use: 2000 SA or M and 2005 SA. SA helmets are recommended. For Time Trial and DE use the following are approved: 2000 or 2005 SA; M helmets are not allowed. Helmets rated Snell Foundation 1995 or earlier and “DOT only” are not approved.
Check with your region for any variances.
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 04-10-2007, 12:11 PM
gestalt1's Avatar
motorcycle helmets also have mor padding around the cheeks and the back edge is usually cut a little higher for better fit on a sport bike.
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 04-10-2007, 04:16 PM
I used a motorcycle helmit at my first De. No one said anything! It had one of those spyder man paint jobs though!
Old 04-11-2007, 03:06 AM
Walt Fricke's Avatar
It slays me that some groups that put on DEs won't allow a Snell M rated helmet. The shells are the same - there is no money to be saved by having two moulds or two techniques for laying things up. The tests the Ms go through are punishing enough that something flimsey isn't going to pass. The SA helmets are tested with the same tests, plus one extra test - on a round form, perhaps simulating a roll cage bar. And then there is the fire resistant stuff. The one question mark might be a company that only made an M helmet, but the major brands make both.
Well, the typical DE allows stock seat belts, nomex clothing is not required, roll bars, far less roll cages aren't required, gloves and fire resistant shoes are not required, and window nets are not required either.
But oh, no - got to have that SA rated helmet.
Something is rather wrong with this state of affairs. And the answer is not to start requiring any of that other stuff, either. That's for racing where the temptation to take risks is a bit higher.
But if you want to drive, you have to meet the local rules, like them or not. Arguing won't do any good at tech.
Walt Fricke
Old 04-12-2007, 10:33 PM
Administrator
Jack Olsen's Avatar
Well said, Walt.
Old 04-13-2007, 12:41 AM
