Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
going to watkins glen and I need advice!
going to a DE there with the Allegheny PCA and I need all the input I can get to be ready! I just did a day at Lime Rock and I know my car is up to it. what can I expect?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 04-25-2010, 11:05 AM
Fun just review some track videos on youtube. So you have some concept of line and breaking points.
Old 04-25-2010, 12:20 PM
just me
paulgtr's Avatar
that I have been doing. it looks awesome. lots of long corners with big elevation changes! and big blue guardrails! oh no!
Old 04-25-2010, 12:48 PM
madcorgi
Guest
Posts: n/a
You'll have a blast. The blue walls are scary for about the first session, then they sort of disappear.
Don't do this, though: YouTube - Porsche 944 spins at glen
Old 04-25-2010, 02:14 PM
Butzip's Avatar
The Glen is great!! From the front straight to the bus-stop it's wide open, then from the Carosel and out of 'the boot' is tighter and more technical. The length and the elevation really give you the feeling that you're 'going somewhere'. Lime Rock is great but blink and you're back on the front straight. The location of the track itself is stellar as well. Wineries, the state park, main street etc...etc... I went for the first time last year and I simply can't wait to go back in June with CVR.
Brgds, Peter Baldauf
1967 912
1988 911 vert
944 TS
1969 911 E
1956 356 Conti
1983 911 SC
Old 04-25-2010, 04:07 PM
just me
paulgtr's Avatar
covered paddock? could have used that at lime rock.
Old 04-25-2010, 04:31 PM
just me
paulgtr's Avatar
how much track time can I expect?
Old 04-25-2010, 04:50 PM
Butzip's Avatar
The garage space was an additional $25, first come, first served basis. I highly recommend it if available. As far as track time.... we did four 20-30 minute sessions/day.
1967 912
1988 911 vert
944 TS
1969 911 E
1956 356 Conti
1983 911 SC
Old 04-25-2010, 04:53 PM
just me
paulgtr's Avatar
how about brake pads? will stock brake pads stand up during the sessions?
Old 04-25-2010, 05:34 PM
Platinum Member
dad911's Avatar
Stock pads should be ok if they are more than 50%. Definitely bleed the brakes before the event. Flush the brake fluid if you haven't changed it this year. It wouldn't be a bad idea to carry spare pads.
Old 04-25-2010, 05:48 PM
lateapex911's Avatar
The glen is great. I can't tell you how your brakes will be with stock pads, but, it wouldn't hurt to have a track oriented pad. I've never tracked my 911 without them, so i have no 'before and after" story, but, I tracked my E46 m3 and burned the stock pads down...smoke, boiled fluid, ...ugly. Now, that was at Monticello, which is maybe a bit more brake oriented, but...
That said, start off late apexing, and work the apexes back. The toe of the boot is pretty late apex, and the reentry onto the NASCAR straight is too. The bus stop can be taken very quickly. If you get a chance, walk or take a bike ride around the track...it's WAY hillier than it appears on TV!
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 04-25-2010, 06:02 PM
Bill Verburg's Avatar
WGI is going to be tough on stock 911 brakes, I'd want a set of track pads and some high temp fluid and as much cooling as possible.
Bill Verburg
Old 04-25-2010, 07:02 PM
Butzip's Avatar
Dead on! Coming back onto the NASCAR track is the trickiest turn in my opinion. Bus-stop is fast in fast out, the esses are awesome, the second to last corner is faster than you think! Have fun.
1967 912
1988 911 vert
944 TS
1969 911 E
1956 356 Conti
1983 911 SC
Old 04-25-2010, 07:09 PM
914 Geek
I recommend fresh brake pads and fresh fluid. I haven't run WG at speed, but I do know it's faster than LRP. My first time out at Thunder Hill (yes, other side of the country) I went through street pads that started a bit over 50%, and boiled the heck out of ATE Blue fluid that was less than six months old. Full (thick) pads, and fresh fluid, would have helped.
--DD
Old 04-25-2010, 07:48 PM
just me
paulgtr's Avatar
what pads do you all recommend?
Old 04-26-2010, 02:33 AM
abcdefghijklmnopqrstuvwxy
htron435's Avatar
Hawk HP Plus is an inexpensive street/track pad that you could drive to & from with. Hawk Blue is full race and an excellent choice -- I run those on the Spec Miata. Both put out a ton of dust, but would be great. PFC 97 quite a bit more but offer long life and limited dust (relatively speaking of course) -- I run these on the SC 3.6. If you go with the Hawk pads, BE SURE TO BED THEM IN PRIOR TO HITTING THE TRACK. You don't want off gassing at the end of one of the long straights!
Jay
2010 Spec Iron Mustang NASA GLD #113
(sold)1981 SC Coupe 3.6 (in '74 Carrera clothes)
(sold)1999 Spec Miata NASA GLD #113
jaynorthauto.com
Old 04-26-2010, 05:41 AM
htron435's Avatar
You can buy the Hawk pads through Tirerack and the PFC's through CStreit @ motodelta.
Jay
jaynorthauto.com
Old 04-26-2010, 05:42 AM
I like Pagids but they are pricey
Pagid choices are
RS 4-2 blue I use these on the street
RS 5 blue -this is a new compound not to be confused w/ the older blue RS 4-2
RS 14 black - too grabby for me
RS 19 yellow my current set they work fine for street and track
RS 29 yellow my next set a little more initial bite than the RS 19
RS 4-2 Blue
Medium friction racing compound with immediate low temperature response. Fading resistance up to 500°C ( 930°F). The RS 4-2 beds quickly and has a very good modulation (controllability). It is a classic Rally compound
RS 5 Blue
New medium friction ceramic type racing compound, fading resistant up to 650ºC (1,200ºF). The RS5's high initial bite combined with the flattest torque curve of all PAGID racing materials guarantees an excellent modulation characteristic and controllability
RS 14 Black
Medium high friction racing compound with high initial bite, excellent release characteristic, very good modulation (controllability) and due to the high ceramic content low heat conductivity. RS14 has a low wear rate and is fade resistant up to a temperature of 650°C (1,200°F)
RS 19 Yellow
Best compound for endurance racing on the basis of the RS14. A slight reduction of the friction value improves the modulation (controllability). Nevertheless, the friction value is enough for cars without power-assisted brake system and ensures comfortable low effort on the brake pedal. Constant temperatures up to 600°C (1,100°F) are possible. The combination of friction value, fading stability and low wear rates on pads and discs (rotors) realised with this material is unmatched up to now. Due to its excellent release characteristics and controllability PAGID endurance materials are also often used for sprint races. A multiple winner of Daytona 24h, Le Mans 24h, Sebring 12h, Spa 24 h, Nürburgring 24h, often with no pad change and usually no disc (rotor) change
RS 29 Yellow
RS29 combines the outstanding wear rate of the RS19 with a slightly higher coefficient of friction and initial bite. Due to its excellent driveability PAGID endurance materials are also often used for sprint races. Application: All endurance racing cars from group N (Speed-WC, Grand Am Cup), Group A up to GT and Sport-Prototypes (Grand Am DP).
also use a good high temp fluid like Motul RBF-600 or Endless RBF-650 or Prospeed GS610
Bill Verburg
Old 04-26-2010, 10:24 AM
I used to run Hawk Blues on my race car, but found them to be difficult to modulate, and they ate rotors for lunch. I switched to Carbotech XP10s, and they are easier to modulate, and more rotor friendly. I'm getting much deeper on the Carbotechs..
That's a race car though, they require heating before they work, like the Hawks. I wouldn't recommend either for the street track combo. The Carbotech equivalent to the Hawk blacks is the XP8, and would be a good choice.
Old 04-26-2010, 05:12 PM
just me
paulgtr's Avatar
can I get them in our area? I am in bridgeport all the time. any other advice I could get about watkins glen would be a huge help. I think I will be there on saturday and definitely the following weekend for mother's day
Old 04-26-2010, 05:39 PM
