Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
scxtasy's Avatar
Tire challenges
I have two sets of Kinesis Mach V wheels that I got with my 964 when I bought it. Both sets have 17x8.5 inch front rims and 17x10 inch rears and are shod with 245/40R17 and 275/40R17 tires respectively (Toyo R888s on one set and Hoosiers on the other). Both sets of tires are well past their prime and need replacing. Although it looks like I can get a new set of Hoosiers or Toyo R888s or R888Rs in these sizes, there seems to be nothing else that will fit. I can go up to 255 width on the fronts (in which case there is a much broader selection of tires available), but changing the rears to 265 or 285 widths yields little change in availability. Anyone have any thoughts on tires that might work, or any other suggestions?
Cheers
Andrew
80 911 SC
94 RS America
13 Cayenne Diesel
06 Cayenne Turbo - Sold
03 996 Cab - Sold
Old 05-03-2018, 08:47 PM
Cajundaddy's Avatar
225/255 are very common 17" sizes. I run these to good effect on my Cayman both on the street and in Time Trial competition. Whether this will work for you depends on your planned use.
https://www.tirerack.com/tires/tires.jsp?tireMake=Hankook&tireModel=Ventus+R-S4&partnum=54WR7Z232XL
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 05-03-2018, 08:56 PM
scxtasy's Avatar
Thanks. What aspect ratio are the 225s?
Andrew
80 911 SC
94 RS America
13 Cayenne Diesel
03 996 Cab - Sold
Old 05-03-2018, 09:15 PM
Cajundaddy's Avatar
Mine are 40 Front and rear to keep the PSM happy on a 2009 car. With my 98 Boxster I ran 225/45/17 up front so the diameter was 25" all around. Run 225/40/17 if you wish to add a bit more rake and put some more weight on the front wheels.
Old 05-06-2018, 02:45 PM
Northern Motorhead
wildcat077's Avatar
Continental makes a 285/40/17 as well as a 255/45/17 that would match your wheels !
I'm using the Conti DW in 255/45/17 and 275/40/17 on my 911 with Fikse FM10's , they're a little soft on the shoulder for track/DE use but they're awesome rain and street tires !
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 05-07-2018, 05:20 AM
Bill Verburg's Avatar
Cheers
Andrew
The largest tires I've seen on a 964 are 245/40 & 275/35 x17
so, first are you sure bigger will fit?
keep in mind that tires have inertial and gearing costs associated w/ them
taller and heavier is more expensive in terms of those costs
for track use R7 in 245/40 & 275/35 are the most usual choice their inertial cost is low grip high gearing cost compared to what you have 275/40x17 is also favorable @~+12 LB-FT available for acceleration
Bill Verburg
Old 05-07-2018, 03:06 PM
totle's Avatar
What other brands, besides Toyo, deliver tires in 245 & 275 ?
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 05-09-2018, 02:47 AM
Continental ExtremeContact Sport. Great summer DD tire that can handle an occasional AX or some light track work if required.
Matt - 84 Carrera
Old 05-09-2018, 04:39 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Cheers
Andrew
If you're looking for another set of track-only tires, the Hankook Z214 is a great value. They are available in 245/40 and 275/40. It's a quick tire (not the fastest but certainly not slow) and has a long life. It maintains its grip level over the life of the tire and doesn't heat cycle-out like Hoosiers do. Hoosiers start to fall off a cliff after a short number of heat cycles.
Could also give the Toyo RR a try. They're offered in 235/40 and 275/40
Kevin L
'86 Carrera "Larry"
Old 05-10-2018, 02:44 PM
Another option for a track day only is the Maxxis RC-1. Come in 235/40 & 275/35. Zero tread so avoid on the street, but they're supposed to wear real well and are inexpensive. I know they're used out west as a spec tire for some road race series. Never tried them myself, so ymmv.
Matt - 84 Carrera
Old 05-11-2018, 06:40 AM
