Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
DMRK's Avatar
Cayenne turbo air suspension help
Hello all,
I've been trying to get my air suspension to work normally on my 2008 Cayenne.
I was getting the usual fault messages and the car was not leveling correctly. I thought it was the valve block so I replaced it, wasn't it. Then I determined it was the residual pressure valve on one corner, I replaced all 4.
Now the problem. Somewhere along the way I forgot to turn off the leveling and now I can't get the car to sit normally. Calibration can't be done unless the car is normal and happy. So my question is how do I get it to normal then?
I have a POR II scan tool and VCDS.
Thanks in advance for any and all help.
I've been searching and can't find the answer.
Old 11-08-2021, 05:18 PM
Information Junky
island911's Avatar
I have seen write-ups on how to "trick" the suspension into a lower set-point. So perhaps search on that for clues on the work-arounds.
Old 11-14-2021, 05:26 AM
Send a message via AIM to fintstone
It seems like you could use the calibration process as it allows you to set each corner...something like this:
https://www.6speedonline.com/forums/cayenne-955-957/302720-tutorial-how-lower-your-cayenne-air-suspension-w-only-durametric-diy.html
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 11-20-2021, 03:30 PM
Cool
Sent from my TECNO CG6 using Tapatalk
Old 12-17-2021, 11:57 AM
