Cayenne turbo air suspension help
Hello all,
I've been trying to get my air suspension to work normally on my 2008 Cayenne. I was getting the usual fault messages and the car was not leveling correctly. I thought it was the valve block so I replaced it, wasn't it. Then I determined it was the residual pressure valve on one corner, I replaced all 4. Now the problem. Somewhere along the way I forgot to turn off the leveling and now I can't get the car to sit normally. Calibration can't be done unless the car is normal and happy. So my question is how do I get it to normal then? I have a POR II scan tool and VCDS. Thanks in advance for any and all help. I've been searching and can't find the answer. |
Information Junky
I have seen write-ups on how to "trick" the suspension into a lower set-point. So perhaps search on that for clues on the work-arounds.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee. ![]() |
It seems like you could use the calibration process as it allows you to set each corner...something like this:
https://www.6speedonline.com/forums/cayenne-955-957/302720-tutorial-how-lower-your-cayenne-air-suspension-w-only-durametric-diy.html
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Sent from my TECNO CG6 using Tapatalk |
Thread Tools | |
Rate This Thread | |
