Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
Yan2947's Avatar
Thanks! Worked on the trailing arms today. Took them off and begin cleaning them up.
1989 911 LS1
Old 05-12-2025, 07:49 PM
Yan2947's Avatar
Has anyone run a 1/2" fuel line for their engine swap? The LS 7 series motors are recommended to have 1/2 " fuel lines. Anyone put in 1/2" lines?
1989 911 LS1
Old 06-15-2025, 01:16 PM
Yan2947's Avatar
Cleaning, painting and reassembly
The slow process keeps moving ahead.
1989 911 LS1
Old 06-18-2025, 07:09 PM
Wow, the red looks good
1980 Euro 911 g9688 LSx chassis car
1982 Euro 911 3.0
1987 Ferrari 308 GTB
2006 H1 Wagon
Old 06-19-2025, 07:26 PM
Yan2947's Avatar
Roof re-do
Today we finished cutting the roof off. Sometimes you have to do things the second time to get it right. Sometimes you have to do it yourself or with friends who I wish I had done this originally.
1989 911 LS1
Old 06-22-2025, 05:52 PM
I’m running 6an fittings and lines.
1982 Euro 911 3.0
2006 H1 Wagon
Old 06-25-2025, 03:24 AM
Carbon fiber roof?
1982 Euro 911 3.0
2006 H1 Wagon
Old 06-25-2025, 03:25 AM
Trailing arms look good. Did you wire wheel them or chemical clean them?
1982 Euro 911 3.0
2006 H1 Wagon
Old 06-25-2025, 03:27 AM
Yan2947's Avatar
Just wire wheel.
1989 911 LS1
Old 06-25-2025, 05:10 AM
Just wire wheel.
Nice
1982 Euro 911 3.0
2006 H1 Wagon
Old 06-29-2025, 10:05 PM
Yan2947's Avatar
Long day working on the fuel lines and then putting the front suspension and steering rack back on, followed by the gas tank. Those fuel lines are a pain in the butt to install, and there is no room for error. Last week I painted the front trunk area to clean it up a little.
1989 911 LS1
Old 07-22-2025, 03:45 PM
Looking awesome!!
Old 07-22-2025, 05:44 PM
Yan2947's Avatar
Wiring
Spent a good part of last couple weeks on wiring and finishing up all the burnt wires and making all the connections. I have a pretty good grasp on everything now I was hoping someone could help me out with this one last harness that I have a feeling I’m going to need as opposed to removing it. If I need it, I might just put a connection on it and then run it to where I need it anyone else tackle it is a photo of the eight wire harness that I originally cut from the other portion of the harness, I believe, probably went to the computer of the original car. here are the photos, one describing the harness, but perhaps someone could give me it in Laymans terms.
1989 911 LS1
Old 07-25-2025, 09:38 AM
Yan2947's Avatar
Getting ready to test Fit the motor maybe next week so I finally got it off It’s GM wooden Crate. Don’t know if anyone knows what alternator did you purchase for your LS? How much amperage did you decide to go with if you know and if you have your model number for your alternator that would be great thanks! Also, which oil pan did you get? My 89 has the flat one this one’s too big I think.
1989 911 LS1
Old 07-26-2025, 12:31 PM
Yan2947's Avatar
I did a little test fit of the engine and tranny today. Want to see where all my wiring will lay out.
1989 911 LS1
Old 08-27-2025, 03:42 PM
This project looks awesome
That red pops like crazy. Definitely following.
Subaru Swapped 1979 911SC (In Progress)
Instagram: Peetsadrives
Old 09-04-2025, 07:28 PM
Looks good
1982 Euro 911 3.0
2006 H1 Wagon
Old 09-05-2025, 07:28 PM
Yan2947's Avatar
Have been working on the wiring for quite a while and finished installing a bulkhead connector from maven Performance. I am able to put the main ECU and the LS7’s fuse box on the floor behind the driver seat. This way I really keep the engine day much less cluttered.
1989 911 LS1
Old 09-15-2025, 01:57 PM
Yan2947's Avatar
Front hood option for front radiator
What do you think of this option if I decide to put a radiator upfront? Similar venting that a GT3 RS might have. I would have to get rid of my gas tank and have the radiator flow up over the hood instead of underneath the car. Just a thought.
1989 911 LS1
Old 10-20-2025, 08:21 AM
Yan2947's Avatar
If you are interested in the files, I purchased them from:
Cebotari3dwork@gmail.com
He has a facebook group and does amazing work. I have not printed anything out yet. I won’t be able to for about two more weeks.
1989 911 LS1
Old 10-20-2025, 08:46 AM
