AirBorne!
Sweet. This build makes me wanna move forward with my plans to slip an LS1 into my VW Rabbit.
wj
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed |
Call me cranky, but this is a technical forum, and all the one or two line post-padding is clogging up a good thread. "Awesome", or "subscribed", doesn't add anything to the discussion. I'm all for being witty or positive and encouraging, but it's getting kind of silly around here.
Back on topic. Are you getting the modified gauges through Scott?
1976 911S Targa, Carrera bodywork, 3.2l engine. |
AKA SportsCarFan
Sounds like a LOT of work to change a 4 cyl front-engine FWD car into a V8 mid-engine RWD car. But it would be way cool!
Doug Miller 1988 Guards Red Carrera Last edited by FastCarFan; 03-08-2009 at 06:53 PM.. |
No offense, but coming in here with 21 posts and being critical of how this forum and specifically this thread is forming seems a bit much. Nice build, it will be interesting to see the finished product!
Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver |
If I could do it over I would have purchased an LS6 intake. Equal gains in HP to the Typhoon and would probably fit 10X better
Good new is I may need to return to Florida in April so maybe I can get the project finished up then. |
yep, im slow in the head
cool project
Couple of thoughts have been running thru my mind about how to do the coolant lines to the radiator. Although I think the current setup will work the idea of the trunk lid opening and closing over time will develop a weak line and it is possible that it will leak.
Has anyone ever used or worked with -16AN or -20AN Fiber braided lines? I am curious to know how flexible they are? I see several of these NASCAR braided lines being sold on Fleabay for pretty cheap and was thinking they may out last my current idea. Plus I could have the fittings welded to the radiator and not have to use hose clamps ![]() Second thought was if these lines could be used would -16AN be able to flow enough coolant thru the radiator effectively? I imagine -20AN lines would be no problem but are probably less flexible. Anyway, interested to hear some feedback on this idea. Here are some pics and link ![]()
Happiest when Tinkering
Very intrigueing project. I am most intrigued by the extra hood shock could you give details on this, mounting location, part number for shock used, ETC. Contact speedo about the braided hose he used it for his oil system.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Friend of Warren
This looks to be a well thought out build, but I have a real concern over that radiator set up. Specifically, won't having the radiator on it's side induce a substantial amount of air into the system unless you can come up with some means of removing all the air out of the radiator? Seems like you will have to have a high point in the system with a bleed valve to prevent this.
Kurt V No more Porsches, but a revolving number of motorcycles. |
(the shotguns)
is there such a thing as a dry sump sb chevy?
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
There are a ton of aftermarket dry sump setups out there for sbc race motors. The only factory GM dry sump motor that I am aware of is the C6 Z06.
yes dry sumps have been around on the sbc for years...but as someone who has had a converted car for years..alot ot these ideas are just things in the way. my oil cooler is mounted in the passengenger backseat area suitably enclosed and vented to the underside of the car and is fed cooling air through two three inch naca ducts in the quarter panel popout window. my radiator is in the front. rubber hoses and a mezziere remote electric water pump are easy to install as well as the front mounted radiator. helps a bit with weight distribution, especially when running an all aluminum engine. i still think that a 930 gearbox is the way to go especially if you want 500 horsepower and then be able to use it...otherwise you end up with power but a bit timid about turning it on! my 71 rs lookalike has an all aluminum 434 sbc with mass flo efi and dynoed at almost 600 chp. the renegade hybrids radiator set up does work well. cannot imagine opening the engine compartment and sticking my head in underneath a 210 to 240 degree radiator!
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp |
You do not have permissi
This is a cool project! What is the weight delta between the v-8 and a 3.6 or 930 motor? Doug
1971 RSR - interpretation |
rh makes a 90 degree for this situation. not sure of flow potential especially with high horsepower.
Nice!---just a thought,---you might consider crossing the radiator hoses over,L-to R at the rad. You may have to use angle fittings ,out of the radiator but the extra hose length and the ,"across the bay",flow
may be less stressful on the hose bending? altho the hose might not like that much axial movement but the swivel fittings would take care of that---Make sense? Apologies for the Art work!
subscribed-
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
