-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   the start of my LS1 conversion: (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/508893-start-my-ls1-conversion.html)
Rebel911 03-30-2010 08:56 AM
the engine is mated with the transmission. I am able to use the cage to help lift and place the engine with one person and very little effort.
i have a few ideas and I am going to take some measurements tonight. I was thinking about pushing the tranny forward and inch.
mkingham 03-30-2010 10:36 AM
Hi Rebel911, I know it just seems like more work to pull the tranny (disconnect the axels, throutle linkage, shift linkage, etc) but you will be glad you did after a few trial fits.
Once you can slide the whole package forward into the shift tunnel, you may be able to lift the engine up and pull it back. You may find that your water outlet will clear after the engine rises to the final position. I also agree with lin7310948, I took the intake and TB off before fitting the engine/tranny package. It gives you a lot more wiggle room.
For me, I didn't have to modify anything to make the package fit. There were two sets of mounting holes for the tranny cross member, I used the set closest to the front of the car and everything fit. Its tight between the water outlets and the rear cross member (1/2 inch), but it all fit with any metal cutting!
Good luck and keep the pictures coming. Mike
Rebel911 03-30-2010 11:01 AM
I took this coming Friday off to put a good 8 hours under the car. The intake is just sitting on the engine for clearance visuals I am looking for a new aftermarket intake to put on there when its time.
i will be pulling the tranny for sure. i don't like that it is so dirty compared to the engine. Further I can flush out the tranny oil completely.
thanks for the ideas, please don't hold back i can take constructive criticism.
ccreddell 03-30-2010 08:17 PM
Originally Posted by Rebel911 (Post 5266680)
I was thinking about pushing the tranny forward an inch.
I read somewhere that the DP 935s had their trans moved forward at least 1 1/2" for better weight bias, so this isnt anything new-and any movement forward is gonna help...
shanghai_todd 03-30-2010 09:20 PM
Wise move, you will not regret it. Also looking at the pictures you should have some lateral movement in the brackets to push the engine and tranny foward. I jacked up the engine lightly and used a pry bar and pressure to "wiggle" the engine and tranny where I wanted it. After doing so I re-tightened the cradle bolts and drilled my holes in the cradle for the anchor bolts.
shanghai_todd 03-30-2010 09:32 PM
BTW, you may want to consider purchasing a motorcycle jack, I think I paid under $75 at Sears and it works great for pulling the engine and tranny together. Great thing about the design is it will go very low.
When working on the motor I placed my roller chair under the tranny to give it support and when putting into the car I removed it and secured the crank pully to the front of the jack to balance the weight.
She moved in and out with no problems, I did however have to use a small floor jack under the tranny to align with the shifting tunnel
http://forums.pelicanparts.com/uploa...1270009819.jpg
http://forums.pelicanparts.com/uploa...1270009846.jpg
Rotornut1 03-31-2010 06:00 PM
Clearance issues
Hey Guys, I'm watching your conversions with great interest. I’ve got a 74 coupe in my garage with an LS2 waiting to go in it. Is also getting a 993 body that needs to be finished before I start engine work. Have nearly all body and RH parts in place, 930 long bell housing. I am going to cut the torsion tube and go with coilovers. Steve at RH tells me I might still have about a half inch clearance problem at the rear cross member, they suggest cutting out the front part of the tube, moving it back, and boxing it back in. I saw that on a couple of their cars at their shop in Vegas. I’m thinking another option; Meziere makes a -12AN block adapter that is 11/16” thick. There are a couple of options for -12AN low profile O-ring 90s. I plan on using braided hose in my engine compartment to dress it up a bit, I’m going to explore the meziere option. Haven’t test fit my engine yet. I’ll start my own thread soon, thanks for all your ideas, Ronhttp://forums.pelicanparts.com/uploa...1270083626.jpg
Rotornut1 03-31-2010 06:02 PM
http://forums.pelicanparts.com/uploa...1270083704.jpg
mkingham 04-01-2010 11:12 AM
Hi Rotornut1,
I bought a set of those block adapters and an AN elbow to try the exact same thing. The problem I ran into was that by the time you put a AN12 elbow on them, you didn't gain any room over the RH solution. Plus, the inner diameter was much smaller than the RH elbows, so you would introduce a restriction in the water flow :(
If you could find a tight 90 pipe elbow (maybe 1 or 1.25 diameter) and weld it to the Meziere blocks, you may be able to buy some clearance and keep the flow. I never understood why the RH block exist out the side for one port and the back for the other. If they exited out the side for both ports, that would eliminate over 1 inch from the current setup.
Keep us posted with what you come up with and good luck.
Mike
Rotornut1 04-01-2010 06:28 PM
Block Adapters
Thanks Mike, I appreciate the info you have provided here also, along with Shanghai Todd. Dang, I knew finding the right elbow would be an issue with flow and size to beat the RH blocks. It's going too be a couple of months before I start posting my build, but will document it here. Using a "Better Bodies" kit that I want to document also as I haven't found much on them here. Car has been dipped and stripped and is in primer now, so hopefully finally at the point where real progress will begin. Thanks, Ron
Rebel911 04-02-2010 02:46 PM
Finally got the engine fully in.
tomorrow is mocking up the radiator.
http://i690.photobucket.com/albums/v...g?t=1270243927
http://i690.photobucket.com/albums/v...g?t=1270243928
http://i690.photobucket.com/albums/v...g?t=1270243929
http://i690.photobucket.com/albums/v...g?t=1270243930
http://i690.photobucket.com/albums/v...g?t=1270243932
the back is sitting right, just have to get some weight up front and put on the lower skirts and bumper.
http://i690.photobucket.com/albums/v...g?t=1270243933
http://i690.photobucket.com/albums/v...g?t=1270243934
gonna take some getting use to getting in and out.
probably should look for a shallower oil pan.
http://i690.photobucket.com/albums/v...g?t=1270243935
Rebel911 04-02-2010 02:47 PM
http://i690.photobucket.com/albums/v...g?t=1270243937
have to clean the garage...
http://i690.photobucket.com/albums/v...g?t=1270244374
dtakenname 04-02-2010 03:01 PM
Hi,
You are doing great!
Just like to know if the oil pan is not too close to the ground?
If so, what could be done about it?
Amazing project!
Rebel911 04-02-2010 04:12 PM
I am researching a shallower pan. maybe from the Cadillac version of this engine.
sc_rufctr 04-02-2010 06:36 PM
I would definitely change that pan.
Surely someone has had the same issue. Isn't there a "standard" solution from Rebel?
shanghai_todd 04-03-2010 01:39 AM
What oil pan do you have mounted now? Take the measurments but it looks to be an escalade or truck pan. Good news is they are completly interchanagble and I purchased a brand new one from GM parts for $175, you will be surprised how much people ask for on fleabay
check out this link
LSX oil pans - LS1TECH
http://forums.pelicanparts.com/uploa...1270283941.jpg
shanghai_todd 04-03-2010 01:42 AM
now after looking at my engine on the jack you can see why I was able to rest the motor flat, I would not have been able to balance it as easy if using the same pan you have as there is a big hump
lin7310948 04-03-2010 07:14 AM
radiator mockup
while you have the windshield out, you should remove the dash cap and close all the holes on the dash as well as possible. lots of places for heat to enter the cockpit. i would seal the radiator enclosure as well as possible. you will be surprised at the heat that builds in the front compartment.
Rebel911 04-03-2010 03:50 PM
Stuff that needed doing:
http://i690.photobucket.com/albums/v...g?t=1270334803
http://i690.photobucket.com/albums/v...g?t=1270334804
http://i690.photobucket.com/albums/v...g?t=1270334805
http://i690.photobucket.com/albums/v...g?t=1270334806
http://i690.photobucket.com/albums/v...g?t=1270334807
http://i690.photobucket.com/albums/v...g?t=1270334808
http://i690.photobucket.com/albums/v...g?t=1270334810
http://i690.photobucket.com/albums/v...g?t=1270334823
ericb 04-04-2010 12:26 PM
I have a chevy V8 to 915 trans adaptor plate and flywheel, if interested.
unclebilly 04-04-2010 08:56 PM
I have a dumb question...
I realize that you cut down the W/S to make it fit. How do you cut the door glass to work with the new rake? It's tempered glass so I understand it doesn't cut well and since it's curved, you can't just use laminate glass here either unless I am somehow mistaken.
Rebel911 04-05-2010 04:04 AM
lexan
Rebel911 04-10-2010 02:53 PM
Notched and braced a part of the cage to get the throttle body in and clear.
http://i690.photobucket.com/albums/v...g?t=1270936015
http://i690.photobucket.com/albums/v...g?t=1270936017
http://i690.photobucket.com/albums/v...g?t=1270936018
willtel 04-10-2010 04:44 PM
Nice canoe.
shanghai_todd 04-10-2010 04:56 PM
Well played on the notch.
Rebel911 04-10-2010 05:22 PM
Thanks, one issue down, plenty more to go.
Craig_D 04-10-2010 08:02 PM
That's what she said! ...haha sorry couldn't resist!
And yes, excellent work on a tight fit. ... ;)
lin7310948 04-11-2010 04:02 AM
notch
rebel, if it was me instead of putting in a 180 degree i would extend the air cleaner on into the back seat area..properly enclosed of course.
Rebel911 04-11-2010 04:18 AM
that's the plan, I am running it to one of the side vents.
sc_rufctr 04-11-2010 08:00 AM
This car will re define "SICK" when it's finished.
Hats off to you for going your own way.
Rebel911 04-11-2010 11:41 AM
Thanks, that was the plan.
An old car that makes people look twice to see the changes I've made.
Crazy horse power to please the inner child.
A car that will be a functioning project for years to come.
shanghai_todd 04-21-2010 09:07 AM
Came across these images of the RUF V8 and made me think of your car for the intake.
Has anyone tried flipping the intake to see what the clearance looks like? Would be interested to see if the if the intake or TB could be modified to use the RUF style filter.
http://forums.pelicanparts.com/uploa...1271865989.jpg
http://forums.pelicanparts.com/uploa...1271866009.jpg
Packy 04-21-2010 09:52 AM
I just read a letter to the editor in Excellence about a guy who was pissed that they featured a LS1 914. I don't understand how these guys can be exclusive "Porsche" lovers without loving just all around automobile engineering. To me it is like loving one supermodel and hating the rest because you did not buy their posters as a child. I am personally a car guy first, porsche guy second. My point being, screw that guy who wrote the letter. I hope you're in excellence one of these days.
Love your LS1 build.
unclebilly 04-22-2010 07:01 PM
I met Scott from Renegade last weekend. What an awesome guy!
One of hs customers showed up to our driving event with a recent renegade LS1 install into a mid year 928. The installation was very sano and the car sounded excellent.
sc_rufctr 04-22-2010 07:37 PM
That makes a lot of sense considering how expensive and complex a 928 engine is to rebuild.
I bet we start seeing more of these 928s in the future.
Rebel911 04-23-2010 04:54 AM
Tonight I'll see what kind of space there is to turn the intake around like the RUF. should be interesting.
Got the harness and computer back. The harness was reworked to leave only what I need. Everything was labeled, relays put in and a fuse block. The computer was programmed for my application, deleting all unnecessary stuff.
http://i690.photobucket.com/albums/v...g?t=1272022845
http://i690.photobucket.com/albums/v...g?t=1272022848
http://i690.photobucket.com/albums/v...g?t=1272022846
http://i690.photobucket.com/albums/v...g?t=1272022847
Rebel911 04-23-2010 04:55 AM
Rebel911 04-25-2010 10:57 AM
Feels like I got hit with a sledge hammer in the face. i have a 102 temp with a sinus infection. I all i got done this weekend is pull the engine and transaxke.
later this week, once I feel better, i will run the harness and start fabing up the exhaust. I hate being sick!
http://i690.photobucket.com/albums/v...g?t=1272217558
http://i690.photobucket.com/albums/v...g?t=1272217598
http://i690.photobucket.com/albums/v...g?t=1272217757
http://i690.photobucket.com/albums/v...g?t=1272217811
http://i690.photobucket.com/albums/v...g?t=1272217852
http://i690.photobucket.com/albums/v...g?t=1272217898
andybullen 04-25-2010 12:33 PM
I love that they labeled everything on the harness - it'll come in real handy if there are ever any issues later.
Rebel911 05-09-2010 05:23 AM
the harness turned out perfect
the exhaust is finished I just have to wrap them. think this will be quiet enough?
http://i690.photobucket.com/albums/v...g?t=1273407193
http://i690.photobucket.com/albums/v...g?t=1273407199
http://i690.photobucket.com/albums/v...g?t=1273407206
