So I think I have the engine in for the last time... I had to move the exhaust a bit do to the fit. Needed about 1" on each side.
Harness is on, I need to pick up some parts I ordered from Bob Johnsons. Then I have to figure out why the harness has a three wire MAF plug and the MAF has like a 4 pin out plug. after that its put in the oil, connect the starter and turn the key for a test fire. then build the cooling system. I pulled the bumper off to better see the engine/exhaust in the car for fitment. http://i690.photobucket.com/albums/v...g?t=1274703645 http://i690.photobucket.com/albums/v...g?t=1274703649 http://i690.photobucket.com/albums/v...g?t=1274703658 http://i690.photobucket.com/albums/v...g?t=1274703666 |
This is Seriously Wild! I love it!
I'm watching this. |
Taking a break. Getting there:
Just for an idea of scale, I am 5'5". http://i945.photobucket.com/albums/a...g?t=1275249019 http://i945.photobucket.com/albums/a...g?t=1275249020 to do list. http://i945.photobucket.com/albums/a...g?t=1275249020 http://i945.photobucket.com/albums/a...g?t=1275249022 they line up better now. http://i945.photobucket.com/albums/a...g?t=1275249023 http://i945.photobucket.com/albums/a...g?t=1275249023 http://i945.photobucket.com/albums/a...g?t=1275249027 http://i945.photobucket.com/albums/a...g?t=1275249027 http://i945.photobucket.com/albums/a...g?t=1275249023 Looks like the ECU is not getting juice or I have a fried ECU [youtube]Ae-NNFCF6Gs[/youtube] |
Thank you for the tons of pictures. I'm finally getting the ball rolling on mine again this weekend (just purchased rad hoses, fuel lines, pump, regulator, and lots of fittings).
I hope to have the entire front end sealed up within the next two weeks, and all thats left is making an engine cradle. |
Man that oil pan looks low.. Check out my post, I have an air intake you might be intrested in :) wont work with my car but will kick ass on yours..
needs some looking around any ideas?
Here is the 1st video: link http://www.youtube.com/watch?v=9KZhqNVA790 |
Hey Rebel, I put a post in Todd's thread (which I am sure you are following), but ...
Holley is having gathering of LS powered cars this September in Bowling Green, KY. I'll be there with my 911 LS6 Cab, it would be great to have a few other non-domestics representing. Mike |
if it's running I will be there. I assume this is Holley as in the carbs.
can you pm me any of the details? thanks it's alive!!! running pig rich since the o2's are not in. looks like I need a new fuel pressure regulator and another muffler. the engine i purchased had 16 slightly bent valves so I had to source new heads... picked them up for $35 complete with springs and valves. God I love working with LS1's. swapped them on in about 1 hour and turned the key. below is the end result. <object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/hdn_efZKK6E&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/hdn_efZKK6E&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object> |
Holley LS Fest info
Holley LS Fest |
Were you guys thinking of participating in the drag or 0~60 events? I do not trust my 915 tranny in either of these so the show-n-shine non domestic would be for me :D
Previous cars I have driven to out of state events and it is not fun burning out a clutch or blowing up a tranny miles from home. Happened with my RX-7 and 12.88 qtr mile Miata.. Let me know, this has gotten my attention now Quote:
I bought the pass for the rally, tour and car show. I have no idea if I will be comfortable tracking my car for any of the hard core events (0 to 60 to 0 or the drag). I guess the more I drive the car, the better I will understand what I am comfortable with.
My gut is that so far from home, it will be best to take it easy on the car since it has to get us home on Monday. OK, maybe there could be a burn out or two along the way, but nothing crazy :) |
If I go it will be a trailer queen on the way down. Way to far to go from NY to KY on a new set up.
I will post a good video of it running tomorrow.
The engine is running strong. now on to cooling it. it is a firebird radiator. I an almost done with the shrouding. tomorrow I am going to ru the hoses to the back and finish the system. Hopefully by the endog the day tomorrow i will be drivable. http://i690.photobucket.com/albums/v...g?t=1276993447 http://i690.photobucket.com/albums/v...g?t=1276993224 http://i690.photobucket.com/albums/v...g?t=1276993274 http://i690.photobucket.com/albums/v...g?t=1276993242 http://i690.photobucket.com/albums/v...g?t=1276993286 http://i690.photobucket.com/albums/v...g?t=1276993293 http://i690.photobucket.com/albums/v...g?t=1276993300 http://i690.photobucket.com/albums/v...g?t=1276993309 http://i690.photobucket.com/albums/v...g?t=1276993778 |
It may be just me but a lot of the ruffs, strosek and several others shaved the rain gutters. this whoe chopped top would flow much better if you shaved the gutters and tig welded the seams. makes the body stiffer also.
decided to paint the car myself. I want to be able to say I did everything myself. (other than the cage) I still have to bolt all the trim, rockers and tail back on and finish painting the inside.
http://i690.photobucket.com/albums/v...g?t=1280758221 http://i690.photobucket.com/albums/v...g?t=1280758227 http://i690.photobucket.com/albums/v...g?t=1280758650 http://i690.photobucket.com/albums/v...g?t=1280758231 http://i690.photobucket.com/albums/v...g?t=1280758232 |
wow, that looks so nice!
Keep going. Did you do anything for the too low oil pan? |
Thanks, I have not changed out the pan yet. I am trying to get the hard to do and weather sensitive projects tackled 1st.
Hopefully some of the other LS1 guys will chime in on this question as well. How much sagging in the rearend are you seeing? If it is anything like mine and as low as your oil pan is I am betting a half throttle launch will make that oil pan drop to the ground from the torque. Granted I have crappy KYB rear shocks and stock torsion bars my car takes a huge dip when the throttle is applied.
Coil overs with helper springs are in my horizon but I am curious to see if this is happening to the rest of the LS1 swappers on this site. Try pushing on your back bumper and see if your pan hits the ground. This may not be a problem for the 930 guys who have larger torsion bars but my SC suspension is not up for the challenge.. |
Is there a cost effective (and non intrusive) way to incorporate improved anti squat geometry in the rear suspension (a la 930)? 930 control arms are expensive and the Smart Racing control arm pivot boxes (I believe) require the rear seat area to be hacked up. IMHO, stiffer springs are in order anyway with your heavier engine, but if you can take advantage of anti squat geometry then you won't need to compromise with an overly stiff ride.
my two cents Keep up the great work! Tim K |
while the observation is interesting, my LS1 weighed in over 50 lighter than the old flat six (stripped LS1 in my car is 425#). A fully dressed LS engine is 34 pounds lighter than the flat six.
LS - 450# flat 6 - 488# When I look at the car the wheel gap looks right; not too squaty. My back seats are stripped however I had the cage/bracing set up so I can plug and play rear coilovers. I don't plan on putting in old tech if I want to maximize output. I do what to keep some of the old look. |
Tim K |
I am not going to put out numbers till I have dyno sheets to prove the information.
i already have a certified weight for the car. If I post estimates there will be may too may non-believers. As for ride comfort, that's why I have a X5. as soon as i fit up a coil over set put we will see how it goes. That will be a winter project. |
David |
Looks great - I like the fact you painted in yourself and in matte black.
I think the car needs to come down an inch in the front an 3/4 of an inch in the back. It may also be time to sell the Fuchs and get an aftermarket wheel that's at least 17". George |
Torque is a wonderful thing but we try and manage the negative side effects :).
Squat is a function of weight transfer (result of wheel torque) and suspension geometry. Generally speaking, squat will increase with wheel torque unless you adjust suspension geometry or move to stiffer springs. Now back to the build! Tim K |
with the wing on. This weekend I am painting the inside and jams. any red on the outside is either being covered by trim or on the plastic from the last spray job. It will be gone this weekend.
wind shield, lights, bumpers are also planned. I want to get it inspected next week. http://i690.photobucket.com/albums/v...g?t=1281130575 http://i690.photobucket.com/albums/v...g?t=1281130580 http://i690.photobucket.com/albums/v...g?t=1281130588 http://i690.photobucket.com/albums/v...g?t=1281130593 |
Thats good. mine was a salvage when i turned it into a slant nose even then. i felt bad once i found out they only made about 120 turbo targas total.
EFI intake
I've been watching with great interest over the last few months the progress some of you guys are making. I'm finishing up the bodywork on my '74 coupe and then will be ready to do my LS2 conversion. I'm going with RH and a front radiator.
I had to take a break from a long summer of sanding to at least trial fit my engine and I wanted to share the success I've had with my choice of intake. I've got the Edelbrock pro flow XT EFI manifold on my LS2 ( part #71403). It easily clears the oil pressure boss so no need for modification there. I've also got the original 90mm throttle body and am using Specter Performance's elbow ( Part #9781). I'm very happy with this setup, not even close with any clearance (of course I'm running a rear spoiler as the manifold sticks out of the lid) Time to take the motor back out and finish sanding the body (that's why everything in my pictures are covered with dust) Will have paint soon then can finish my mechanicals. I want to thank shanghai_todd, mbaran, Rebel911, mkingham, and bunch of other guys on this forum who have helped me plan this project. I'll start my own thread when I have a little more to offer. Thanks againhttp://forums.pelicanparts.com/uploa...1285042421.jpg http://forums.pelicanparts.com/uploa...1285042433.jpg http://forums.pelicanparts.com/uploa...1285042449.jpg |
the 15's are going this winter.
I like Rotornut1's build looks clean. Well, lets play name that noise... any ideas? I have 50 psi of oil pressure at ideal and good rising pressure when accelerating. Engine is cool to warm as I only drove it ~200 yards to record the sound. http://www.youtube.com/watch?v=RMLyinXhW6U Forgot pics of the car now and the new pan. The rear window is going for dark tint tomorrow. http://i690.photobucket.com/albums/v...g?t=1286143455 http://i690.photobucket.com/albums/v...g?t=1286143462 http://i690.photobucket.com/albums/v...g?t=1286143465 http://i690.photobucket.com/albums/v...g?t=1286143470 Old pan http://i690.photobucket.com/albums/v...g?t=1286143366 New pan http://i690.photobucket.com/albums/v...g?t=1286143435 http://i690.photobucket.com/albums/v...g?t=1286143441 http://i690.photobucket.com/albums/v...g?t=1286143545 |
sounds like a lose rod.
Or flywheel bolt... balls
You might cut the oil filter apart and look for desbris as signs of a rod bearing being chewed up.
Is there anything hitting/rubbing the chassis which you overlooked? |
Second thought: Is there a baffle or something different about that oil pan that could be mis-aligned or flipped up that is hitting the rod?
I would remove the pan and start checking for a scared area or lose rod. |
I am going to 1st short each coil, one at a time, to check to see if it is rod knock. Next I am pulling the valve cover and oil pan to check for cover wear. Last I am going to pull the engine to check the flywheel bolts. nice! good thing my wife is going to a retreat with her sister this weekend. |
i just saw a 944 with an ls1 this weekend at a DE. he said it had not hit the dyno as he had just finished a week ago or so but his estimation was 400hp/400ftlb. poor guy has clutch problems and could not go out on sunday but we had been sharing the same instructor who said it was like being belted to a rocket.
| All times are GMT -8. The time now is 01:40 PM. |
