Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
ChrisP911's Avatar
a lot of good info thanks
Old 12-28-2012, 10:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #241 (permalink)
Yan2947's Avatar
Just looking for wheel opinions on Plasti Dip
Just sprayed Plasti Dip on one side of my 89 911 Fuchs. Just curious what people like more before I do the other side or pull off the plasti dip? Give me your thoughts.
1989 911 LS1
Old 03-20-2013, 03:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #242 (permalink)
Would keep the silver and tint the windows.
Old 03-20-2013, 03:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #243 (permalink)
I am personally stuck on the stock rims.
Old 03-20-2013, 06:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #244 (permalink)
ChrisP911's Avatar
all blacked out looks good
Old 03-26-2013, 11:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #245 (permalink)
Yan2947's Avatar
Just did a launch from 0 to 60 launch which took only 3.82 seconds from a start in second gear. Pretty fast for a stock LS1 and a G50.
1989 911 LS1
Old 04-14-2013, 01:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #246 (permalink)
I vote for stock. Nice video
Old 04-14-2013, 04:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #247 (permalink)
Yellowb1rd's Avatar
Yan... being one who has actually gone through this conversion ('79 911SC) from beginning to end (not LS1 but carburated), I have to tell you that this is not an easy conversion, and the expenses pile on quickly. Be prepared to spend a good deal of money on the project, and even more prepared for the countless little items that you will need to purchase that continue to add up into seemingly infinatum.
I am as we speak having to remove the motor for the fourth time, and I'm putting a much more mild 350 into it, as the fire-breather (500 HP) was just too prone to overheating, and was incredibly unreliable. So much, that I seriously considered going back to the basics and yanking this thing out and putting the original 3.0 liter back in. It's been a lot of fun when it actually ran well, and the issues were sorted, but I never felt comfortable driving the car further than 50 miles from home. The power this car possessed is indescribable, but it's no good if you're constantly looking at the temp guage. These conversions are very prone to overheating [and many are hack jobs] so you've got to have the right engine and more importantly, a well-designed cooling system. I purchased everything from renegade to do this conversion (including radiator, and water pump), followed their instructions (which you can print out when you buy the kit) closely, and STILL had overheating issues. I believe that most of those issues stem from the motor, as I do not believe that it was rebuilt correctly. I'm hoping a more mild motor will change all that. Even with a relatively mild 350, you should see similar performance as the 930's of your era.
All my items were purchased from Renegade, including the rebuild of the 915 trans-axle ($4500). Your G50 is even stronger than my 915 (neither as strong as the 4-speed 930 trans), but if your trans-axle is tired, expect it to wear out more quickly than it ever would with the 3.2 liter. Remember, it's the low RPM torque that these 350's generate are what really put a strain on the stock Porsche trans-axles. I would recommend checking out Renegade's site for more information. Again, this is just not a conversion for the feint of heart.
If I could do it again, I probably would have stuck to the stock set up and turbo-charged the motor, but the entire process/project was a great learning experience, laced with frustration.
I can provide pics of the car in different stages, if you would like...
Old 04-14-2013, 06:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #248 (permalink)
Yan2947's Avatar
Yellowbird, would love to see some photos! My build is almost 3 years old. My first engine had problems - it was used - As I mentioned in a previous post I would only buy a new motor. It seems that too many people had issues with their used LS1 or LS based motors. This second motor was a new long block LS1 from a GM dealer. $3K for new. Why I ever bought used I have no idea. This motor has been running without any issues and I would drive it across country without any thought. The G50 is strong and I see no future issues. I bought my kit from Renegade and they were incredible help. The cooling is the issue that everyone thinks about. I decided not to hack up my car and put in a rear radiator with some help from toyjet. Some of that help happened after I installed the radiator. I have a single pass radiator from Ron Davis. I ordered a new duel pass radiator (actually ordered a triple pass buy they could not build it) more then a year ago. They can be very slow. I have a double pass radiator coming soon... My cooling was only an issue when the temp outside was in the 90's and very humid. I never overheated but didn't like seeing the temp rise to about 225. The double pass should lower the temp by 20 percent. We shall see but any cooling will only help. The cost to build was not too bad compared to having to rebuild my 3.2 If I break down in the future - anyone service shop can help out. As I mentioned in my previous - the power one receives from a stock ls1 is pretty impressive. If I had a 915 Tranny I would probably not do a launch but the G50 is different - I believe pretty close to the 930 tranny but not quite sure about that. Lets see some pics!
Yan
1989 911 LS1
Old 04-15-2013, 03:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #249 (permalink)
radiator
hey guys i live in CA and i had the same problems
now i use a triple pass radiator i made by just cutting two slices in my radiator tanks evenly spaced and placing thin plates in the cuts sealing with aluminum radiator repair kit. takes 1 hour or less and 2-2500cfm fans sucking air from bottom.
i run a 355 with 360 hp 400 fpt and 175 thermostat and it never over heats, in fact the faster i go the cooler it gets.....on a hot day 95+ at idle for 20 min it gets to 182
before i put the thermostat in it would not even get warm, also make sure all bends are not being sucked closed by water pump by placing hose clamps on the part of hose. i guarantee it will make a big difference i almost gave up until i discovered this cure my self. i drive this car every day no problems would take it anywhere.
Old 04-15-2013, 07:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #250 (permalink)
Engineer of profanity
924CarreraGTP's Avatar
Crankshaft bearing failure on your LS1 engine? Aww, That's so sad. Maybe if you wouldn't have put mass produced trash into a precision built machine, you wouldn't be spending that money twice for another junky wear prone engine. The crankshaft bearings on my 1970 2.2 liter 911 T seem to still be in great shape. They're over 40 years old and in an air cooled engine. Ha ha ha Please don't even go there on the overheating issue being an excuse. Porsche engines are air cooled and yet they don't seem to have a problem with overheating. So save us the B.S. I'm still skeptical on weight savings as well. These Chevy fans can claim whatever they want, but that doesn't make it true. If any of these cut and shut truck mechanics were Porsche mechanics they wouldn't be so scared to rebuild a simple Porsche 911 engine themselves and add on some nasty horsepower bits.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 04-16-2013, 01:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #251 (permalink)
R.I.P.
drmatera's Avatar
yeah, porsche engines never break. And besides why spend $10k on a 500hp motor when you can spend $40k on a 300hp motor. you hybrid guys are stupid
Old 04-16-2013, 02:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #252 (permalink)
lin7310948's Avatar
i think that my feelings are hurt??? such hurtful comments are just so uncalled for....
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp
Old 04-16-2013, 02:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #253 (permalink)
The only people who spend $40,000 on a Porsche engine don't know how to do the work themselves. You're right, overhead cam 6 cylinder VW derived engines are too complex for the average Chevy mechanic to rebuild. Don't pull that 500HP B.S. either. I assure you there are 1980's 930's with 600+ HP. The difference is that they will run 600HP all day and night without bearing failure. I'll pee on your Corvette engine if it overheats. That should fix it.
Oh, and don't you mean $20K on two 500HP engines since you are now doing it all over again?
Old 04-16-2013, 04:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #254 (permalink)
R.I.P.
drmatera's Avatar
Really? 600hp stock 930 engines can run non stop without failure? Wow all these dumb Porsche guys spending $50k on a rebuild must be Chevy guys at heart. Man they are dumb
Old 04-17-2013, 05:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #255 (permalink)
you need to take a ride
i think you need to take a ride in my car....
i was invited to join pca Fresno Porsche club and i have a 355 Chevy motor, the fellows there where skeptical as well until i let them sit in it my car, then they voted to have me as a member, the look on their faces as they put their foot gas was worth a million bucks, the roar of horsepower is addictive..... at $3500 a pop. check out summit racing it's in black and white, besides what is the fun about having something everybody else can buy when you can build something different.
this is if you have the balls to try something out of the box....
Old 04-17-2013, 07:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #256 (permalink)
i think 928 suck, what a pile of ****
Old 04-17-2013, 07:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #257 (permalink)
That shows how smart you are. The Weissach axle in the 928 was later adapted to the 993 (911) because the 928 handled better than the 911. There are many Youtube videos of 928 race cars outrunning everything from Corvettes to 911RSR's.
Not to mention Chevrolet stole the rear transaxle layout from the 928. It's the only reason those heaps have been competitive lately. It's funny that you guys convert 911's for their handling. lol
Also, the Porsche 928 was the top of the line at Porsche, the most expensive car you could buy from Porsche (shy of the 930 which was a special order), and also the fastest car you could buy from Porsche. The 928S4 was faster than the 911 Turbo. I guess that shows who is dumb here.
The problem here is that you guys aren't Porsche mechanics, nor do you belong in Porsche clubs. What you need to do is leave the 911's to the real mechanics and go modify Corvettes. That's just my opinion. Opinions are like *********s. Everybody has one.
I don't care what Porsche club you weasled your way into. You don't belong there with your trashy LS1 engined car.
For the record Porsche is statistically the most winning endurance racing car manufacturer in history. When Chevrolet has over 28,000 endurance racing wins, come talk to me. Nascar doesn't count. Cars that are built to run together have no relevance to endurance racing wins. The End...
Old 04-17-2013, 11:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #258 (permalink)
There's a local 1980's twin spark Porsche 930 Turbo with over 600HP. The front end bows up when you hit the gas and you dare not mash the throttle for fear of flipping the car. I'll stick to Porsches for my speed addiction. There's nothing a Chevrolet engine can do that a Porsche engine can't do better. I never said anything about "stock 930 engines". You guys are talking about "building" cars and horsepower, yet you're scared women when it comes to rebuilding Porsche engines or building more horsepower into them. That's the fun in building Porsche engines. You guys are just making Porsches boring with trashy mass produced gas guzzling engines. All because you are too lazy, unskilled, and cheap to build a fire breathing Porsche engine. It's stupid and I think you guys look ridicules.
Old 04-17-2013, 11:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #259 (permalink)
CorsePerVita's Avatar
Awful lot of hate in thread, although some kind comments. At the end of the day, if someone wishes to spend $10,000 on their car, or $100,000 on their car, it is their money and their car.
If it makes you happy, if it makes you smile, if it makes you feel good, then it's money well spent... regardless of what others say. I've seen everything from people who have told me that it's a terrible thing to drive my car in the winter and as my daily because it "devalues the car" to people who have said "that is what they are meant to do, be driven" so there is always an awful lot of opinions.
Don't do it because people hate it or love it... do it because it makes you happy.
1970 Porsche 914 1.7L, 1982 Porsche 911 SC Targa, 1977 Porsche 924, 1979 Porsche 924, 1999 Ducati 900SS
Old 04-17-2013, 12:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #260 (permalink)
