-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   89 911 LS1 Conversion (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/556905-89-911-ls1-conversion.html)
Don Nguyen 11-02-2011 03:26 AM
Originally Posted by mkingham (Post 6345191)
Hi Don,
I bought a set of headers that fit around the RH brackets. They were made by JBA Performance Exhaust, part # 1850S-3
Here are two pics
http://forums.pelicanparts.com/uploa...1320194843.jpg
http://forums.pelicanparts.com/uploa...1320194857.jpg
That's awesome. For ~$400 that I see them selling for, that's a deal.
sirhiss 11-06-2011 08:30 AM
Hello
What do you guys use for rewcounter? i have bought a 912 tacho because i have read that the ecu gives out a 4 cyl signal but it dosent work. Help me:confused:
Yan2947 11-07-2011 03:49 AM
My tach went out to North Hollywood Speedometer and Clock Company. Serving your gauge needs since 1955. VDO, Porsche, Mercedes, BMW, Volkswagen, Veigel, Veglia
they take the 911 tach and convert it to the 8 cyl engine. It cost about $200 i think. Works like a charm.
LJ851 11-07-2011 08:53 AM
Originally Posted by sirhiss (Post 6354991)
Hello
Have you seen this?
http://forums.pelicanparts.com/porsche-911-technical-forum/627935-tachometer-adapter.html
Don Nguyen 11-07-2011 08:55 AM
When I put an LS1 into my BMW, all I had to do was change the tach output on the PCM to a 6 cyl instead of the 4 cyl signal it was originally putting out.
Don Nguyen 11-08-2011 08:27 AM
I just noticed on a lot of these swaps, are people no longer running power steering?
LJ851 11-08-2011 02:08 PM
Most or all of the cars you are talking about never came with power steering as an option.
toyjet2000 11-08-2011 05:42 PM
I do not normally respond to post on purist Porsche comments because it is like debating politics. Just so everyone knows my position,
I own a Corvette also. I wanted a vehicle with the power of a Vette but handle like a Porsche 911. I can truly say (in my opinion), I now have the best of both worlds.
racer_X 11-08-2011 06:14 PM
This is a very interesting build, I love the details, but not sure if I buy into the idea yet. I am just wondering how well would handle..... even if the LS engine is technically lighter (and not by much if I understand correctly) isn't the center of gravity much higher with the V8? And isn't the car still heavier overall with the additional weight of the cooling system and coolant? I would be nervous entering a corner with the weight that high (though I like the LS's accessories position, nice and low compared to the flat six).
Someone enlighten me: it seems like this conversion is for those who appreciate a straight and flat track, but has anyone run this set up on a road course?
toyjet2000 11-08-2011 07:44 PM
LS1 conversion center of gravity
Although the center of gravity did change:
My Porsche 911 equipped with the LS1 conversion and Toy-Jet rear mounted cooling system installation yields a combined weight savings of 21 pounds lighter at the rear of the vehicle. I had to fill the fender wells back up with 17" wheels to get rid of the excess gap my lighter LS1 setup made. I could have adjusted my suspension to compensate for this issue but I wanted to take advantage of the more top speed end the taller tires gave me. I have to be honest and tell you that I have never done a road race or obstacle course, I only drag race occasionally.
Scott R 11-08-2011 08:07 PM
This doesn't add up, a 3.2l weighs 380lbs a ls1 weighs 450lbs, without a cooling system attached to it. Depending on the position of the ls1 you would get the fender gap if the weight was farther forward. But I don't see how it could be lighter...
toyjet2000 11-08-2011 08:50 PM
I did this comparison about 11 years ago. I took both setups to the refinery where I work and put both setups on a scale.
See the results at:
Toy-Jet.com
Don Nguyen 11-16-2011 09:14 PM
What kind of water pump is used in place of the original factory piece?
toyjet2000 11-17-2011 05:58 AM
An inline pump that pumps at least 55 gpm.
mkingham 11-17-2011 12:50 PM
Hi Don, I used a Meziere 55 GPM remote pump (Part # WP316B) If you look at the 2nd photo on post #199 (or 200) you can see it mounted to the RH engine cradle. It is blue.
Mike
Yan2947 11-17-2011 02:27 PM
Well, I weighed the car the other day. For some reason, I don't think the scale was correct. I used the local transfer station at the dump and they weighed the car in at:
2940 lbs. When I started the conversion out it weighed 2612 lbs. I am getting my new torsion bars put in - 30mm in the rear and 22mm in the front along with adjustable spring plates. The photos below show the new parts. When I measured the distance from the ground to the bottom of the wheel well originally I had:
LF: 26 1/8" NEW HEIGHT - 25 7/8"
RF: 26 1/16" NEW HEIGHT - 26"
LR: 25 3/8" NEW HEIGHT - 25
RR: 26 1/8" NEW HEIGHT 25.5"
So, once the corner balancing is done the car will be re-weighed and it should be pretty accurate. Anyone else see any difference after weighing their ls conversions?
http://forums.pelicanparts.com/uploa...1321568719.jpg
http://forums.pelicanparts.com/uploa...1321568746.jpg
http://forums.pelicanparts.com/uploa...1321568773.jpg
Yan2947 12-08-2011 10:43 AM
The following work is complete by my mechanic:
Replaced front torsion bars 22mm
Replaced rear torsion bars 30mm
Replaced spring plates with adjustible spring plates and installed poly bronze bushings.
Set height, corner balance and align. Height 25 1/2 at front fender lip and 25" at rear fender lip.
Weights:
562 545
926 898
for a grand total weight of 2931 lbs without driver and tank 3/4 full
includes porsche air pump/tire, etc... Nothing left out. Stock as you would buy at the dealership except for the LS1.
My initial weighing when I started this build was flawed. I used a truck scale and now found that it was way off. It was used to weigh commercial trucks. My car barely tipped the scale. The build with the 350 hp ls1 showed to be about the same weight. No gain - no loss - radiator on a steel rear lid turbo wing. Not bad.
911JeffS 12-10-2011 12:49 PM
Yann-
Congratulations! On your hard work. Nice choice of components. I would love to see video. How about some more you tube posts? (hits r good) I've subscribed there as well. Lets see that beast in action!
Jeff
Yan2947 12-11-2011 06:53 PM
Jeff,
I will try and get some up there before the snow hits! Perhaps in the morning I will take it out on a run. Huge difference with the new torsion bars. The squat is gone and the ride is firm but comfortable. I need to get some heat. I am waiting on Clemmons at Toyjet. He has some great ideas. My plan (at this time) is a heater box (if I have the room) around the mufflers and then port into the stock ducts. We shall see...
Kyle Saenz 12-11-2011 10:20 PM
I thought your original weight sounded kind of light. Congrats on the car must be a lot of fun. I just got done doing a turbo build on my 3.2, I am making about 360hp also. it would be very interesting to see how the cars compared in a straight line! (although i am sure it would probably go to you due to your massive torque!)
911JeffS 12-12-2011 12:55 PM
Road less traveled
Yann-
Without question the torque of our V8's requires larger bars front & rear. As recommended, I'm going to use same components 30 tb rear 22-23 tb front. Would you mind expanding on the adjustable spring plates ? What company(ER) ? happy w/the products ? I like the setup, as I see it, the suspension would have full rear travel, only restricted by the 30mm tb.
How does it feel compared with the original setup? Is it your understanding also that the adjustable SP w/poly-bronze bushings gives the big 30mm a less harsh feel ? Compared to the original SP w/rubber bushings that twists/binds, as opposed to the free moving new setup. I have never driven my car, so I have nothing to compare it to. Can't wait to see some video.:eek:
Yan2947 12-12-2011 03:44 PM
Kyle, not sure about my HP yet but there is no turbo lag. I love the ride. The car handles like a porsche. I'm not sure what other 89 911s weigh but I'm sure they are close if they have not been stripped. Jeff, my setup is from Elephant Racing. My mechanic ordered them. The product is great so far. The feel is not so different. Certainly stiffer but comfortable. The squat is gone and that was my main concern. Didn't get a chance to do any videos but I will try one of these days...
Yan2947 01-08-2012 03:30 PM
Bad news and good news. Well, a Crankshaft bearing went on my LS1. Not good. I have seen everyone who purchased a used LS1/x have problems and I guess I'm not exempt. I was told about 2K to rebuild it. I paid $2500 originally for my LS1 and the new GM long block was only $3100 delivered without a core charge from crateenginedepot They were great and super fast! I am taking off the components I need for the new long block from my old motor like the intake, etc... I did spend some time thinking if I should go to an LS3 or or LS7 but really, why? I'm not racing the car and it is way too powerful as is to warrant the extra bucks on the extra horse power. If this was my first build I would seriously recommend anyone to just purchase a crate LSx of your choosing from GM Performance or a company like SLP Performance where you can get an LS3 long block with over 500 hp for just over $7000. You never know what you are going to get with a used engine!
If anyone wants to rebuild an engine I will let my used/blown LS1 long block go for $500. It has a fairly new oil pan (my new crate came with an oil pan). I have a crate to ship it if you pay the shipping or pick it up in 12486.
http://forums.pelicanparts.com/uploa...1326064786.jpg
http://forums.pelicanparts.com/uploa...1326065251.jpg
Scott R 01-08-2012 05:37 PM
Are you looking into the root cause of the failure? I wouldn't be dropping more engines in unless I knew exactly how the last one failed.
Yan2947 01-08-2012 06:05 PM
Scott,
We knew there was some play in the crank. It was slightly out of spec. My car would stall sometimes when the clutch was depressed making us think that the crank sensor was not always engaged. Not sure but eventually it got bad quick. The vehicle the motor came from was salvaged with 65K miles but the insurance agent told me that it was a front side impact and not a head-on. He did not think that could have caused the destruction of the motor. My oil pan once hit the ground, cracking the pan as indicated in earlier posts. Other then those two incidents there appears to be nothing else. I have since put on a skid plate and recently got my tornsion bars upgraded to 30mm in the rear and 22mm in the front. No more squat. Hopefully I will never have an issue again. The new motor comes with a pretty good warranty. Are you thinking there could be something else?
Yan2947 01-09-2012 06:03 PM
Well, the new ls1 has the ls6 valley cover and the batwing oil pan. I have the old ls1 style intake so I see there will be some changes coming. Is a new LS6 intake mandatory or does it just make a whole lot of sense.? Anyone chime in...
Yan2947 01-19-2012 10:04 AM
New engine is in. John is finishing off some final new changes to the cooling system. I switched out the RH water pump adapter for toyjets water pump adapter. It gives a lot more room between the adapter and the back of the car and it looks like you could take it off without removing the engine. The only issue with the water pump adapter is that it would like to have the electric water pump on the driver side of the motor. Anyone starting from scratch it would be easier to do. We are just re-routing the hose to bring it to the opposite side of the motor. The new LS1 long block looks like it is for the corvette with the batwing oil pan. It has a lower profile then the Camaro oil pan. Hopefully my skid plate will fit. The valley cover is the newer style and should yield a bit more horsepower.
http://forums.pelicanparts.com/uploa...1326994114.jpg
not_hans_stuck 01-19-2012 10:19 AM
This is one of those apples to apples things.
I think an LS1 has a higher center of gravity than a flat 6. I think a turbocharged flat 6 with the intercooler and all that other stuff mounted way up high, has a higher center of gravity than an LS1. Since the LS1 is in the same power class as a turbo, the center of gravity advantage goes to the LS1.
Incidentally, the same goes for weight also. I think the LS1 and normally aspirated flat 6 are close in weight - Clemons reports a 25 lb difference which is certainly within the error range of a big rig scale. However, once you've added a gigantic intercooler, turbocharger and all the plumbing of a turbo motor, the LS1 provides a clear advantage.
Let's remember we're talking about 400hp cars, not 200hp cars.
And then, of course, there's the fact that a 400hp Porsche motor is on the ragged edge of tune and not really all that tractable, while a 400hp LS motor is basically what I have in my Suburban -more or less.
I drove Clemons car and while it's surprisingly fast, the most amazing thing was how civil it was if you didn't provoke it. Amazing.
Hal
Yan2947 01-19-2012 11:31 AM
Hal,
wow, you got to drive his car? Was it the supercharged one or the stock ls1 car?
not_hans_stuck 01-19-2012 06:17 PM
Originally Posted by Yan2947 (Post 6504314)
Hal,
The stock one. The silver targa. The supercharged car had the motor out.
He's a really great guy. He offered, I didn't even ask.
I already had the RH kit on order though - and I prefer the radiator in the nose. The wing radiator is a very innovative idea, but I had already created the look I wanted and couldn't go back. Also, I'm obviously not afraid to take a sawzall to my car. :eek:
Using Toy Story as a reference, I was more Sid than Andy.
H
Kyle Saenz 01-19-2012 07:06 PM
it's funny how if your doing the work your self you could almost have the RH kit, and a BRAND NEW lsx engine for the cost of a quality rebuild on the flat six.... with no real disadvantages.... hmm
not_hans_stuck 01-20-2012 04:16 AM
The one potential disadvantage ,is the effect on resale. It may or may not have a direct affect on price, but it will limit the cars appeal thereby reducing the potential pool of buyers. It becomes more of a hotrod and less of a collectible classic.
I have no idea what that does to price. I suspect a well executed conversion would get a good price, but it might be harder to sell.
Of course, if you dont care about that, then it isnt a factor.
You do lose the flat six sound and thats sad, but I can live with that.
lin7310948 01-20-2012 05:05 AM
i have never even considered the resale value of the car after the conversion. i do not miss the flat six sound either! i do love the 911-930 body style and design but wanted a somewhat cheaper and simplier high horsepower engine. so my two conversions were to my liking. and, the Mast Motorsports LS 427 SS drive by wire engine was not cheap but it has forged internals and develops a bit over 700 CHP... as a bit of advice..i would build a bulkhead between the radiator shroud and the gas tank that seals off the heat from the radiator enclosure that might escape into into the front compartment. the porsche dash is not very well sealed.
not_hans_stuck 01-21-2012 05:35 PM
That's good advice about the firewall. I've been looking at that. The shrouding for the radiator is pretty loose fitting. I need to see how the renegade gas tank fits though. It might form the firewall.
I also know that the front of a 911 is pretty wobbly and I'd like to do something to shore that up a bit. I was thinking a full width firewall made of steel and welded into the front trunk would form a pretty good stiffener. It would be a complete redesign of the front radiator area though.
I don't know if I'll miss the 911 noise or not. We'll see.
As far as resale, it's just another data point. It ranks low on my importance level, but I still have a kid to get through college and the car is the emergency fund.
Well, the emergency emergency fund....
H
Yan2947 01-25-2012 04:31 PM
Originally Posted by slow&rusty (Post 6503545)
Weight of my car shown on the corner of the building (2940lbs).
My car in this pic is on 3/4 tank of gas and has B&B headers and muffler, everything else was factory right down to the Fuchs and A\C
http://pic20.picturetrail.com/VOL86/.../102900191.jpg
Hope that helps.
Just an FYI... Checking weights of other stock cars and found this nice 930 weighing in at 2940 as shown on a scale. I've added my weight at our local weigh station below which shows the exact same weight, mine having an LS1.
http://forums.pelicanparts.com/uploa...1327537395.jpg
Of course, mine is a 1989 911 with a G50/01 and I am not sure what year his 930 is and what tranny it has. I have the same rear lid and wing with slight mod and he has a inter cooler where I have a radiator. My fenders, tires and breaks weigh a little less also. Hopefully, he won't mind me borrowing his post but it does show an apples to apples comparison, almost.
heliolps2 01-25-2012 06:52 PM
I think you can use a 993 twin turbo deck lid and tail , i believe that you can get all stuff under that tail, just a thought
Yan2947 01-25-2012 07:09 PM
I like the 930 lid and the way this turned out. I know its a mod to a stock wing but it works. I really had to vent the back. Moving the radiator a little more towards the rear keeps the fans above the back of the motor close to the lid latch and allows most of the hot air from the radiator to pass out the back. The new long block is almost complete. Hopefully it will be running again by next week....
Yan2947 02-12-2012 06:17 PM
Just put up a new video link on youtube after driving the car today:
89 Porsche 911 LS1 - YouTube
Nothing too special but you get to see a bit of the wonderful RH Kit and the toyjet water pump adapter along with the toyjet inspired radiators from Ron Davis.
toyjet2000 03-05-2012 01:31 PM
Beta Test
I am beta testing my new LS1 Water Pump adapter.
Its inlets and outlets are now inter-changeable to better adapt to any
configuration.
See more Pics at: Toy-Jet.com
Page 10
http://forums.pelicanparts.com/uploa...1330982833.jpg
toyjet2000 03-24-2012 10:55 PM
Yan, I tested my latest wing design. I drove my car 50 miles. I averaged 75 mph. My temp. went to 195 degrees then the fan came on and my temp settled at 180 degrees. At idle I was about 160. It was 80 degrees outside when this test was done. See pictures of my new design at my web site at: Toy-Jet.com Reference page 2, titled New Design 2012. Thanks.
