-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   first purchase for another LS conversion (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/572603-first-purchase-another-ls-conversion.html)
lin7310948 10-30-2010 08:11 AM
this is the first purchase for my latest conversion...LS7 deadheaded fuel rail filter and pressure regulator...cost 50 bucks at O'Reillys! before the naysayers jump in..please dont...let me say that i am 70 years old..and do not wear gold chains and unbuttoned shirts...but i do like the potential of the LS7 conversion....and i am not saving my 78 930 for anyone but me or my heir to be! the conversion will use Renegade Hybrids basic kit, Mast Motorsports LS 427 Black Label 675 HP SS drive by wire engine, Livorsi Gauges tied to the Mast ECU and including GPS speedo... the gauges will be black face and bezels with red pointers and white digits... i will install this in my already much modified and lightened 78 930. i am not into driving events but i do like hotrods! i dont know that i can add much to the info and pictures that are already available on the other LS conversions on this forum...but will be using the same as a template for the conversion..http://forums.pelicanparts.com/uploa...1288451403.jpg
Tooth911 10-30-2010 08:21 AM
Iam with you man, now if the Gt2rsr guys had that v8 power ....
lin7310948 12-07-2010 09:18 AM
radiator is here and the gas tank cut down, welded but not finished. braided stainless steel gas lines installed along with walbro 255 lph fuel pump. gas tank will hold approximately 18 gallons by my calculations.http://forums.pelicanparts.com/uploa...1291742279.jpg
lin7310948 12-08-2010 05:21 AM
hargett shifter
930 4 speed shifter and linkage arrived has arrived. i have one of the first shifters in my other conversion. this latest version appears to be much improved. i really like the shifter position...much closer and higher!http://forums.pelicanparts.com/uploa...1291814429.jpg
lin7310948 12-08-2010 09:23 AM
this is the car...1978 930... that will be converted. i have owned this car and its many variations since 1991 or 92. car had been converted to a slopenose when i purchased...and was guards red. the factory color was continental orange. might change it back to that one of these days, but not now. i have replaced the gt2 tail with a factory 930 tail and will most likely run a ducktail when it is street worthy... and yes, it has genuine RUF yellowbird bumpers/spoilers. already sold the Ruf gauges as i will use Livorsi gauges.http://forums.pelicanparts.com/uploa...1291828937.jpg
lin7310948 12-09-2010 09:10 AM
received the renegad hybrids ls conversion kit to include the KEP stage 2 pressure plate and organic race disc, flywheel, hardened ring gear, t/o bearing and engine adaptor.http://forums.pelicanparts.com/uploa...1291914569.jpg
herman maire 12-09-2010 02:32 PM
Sounds like a nice engine.
I have never looked into doing a conversion like this but how much would you be looking at cost wise ? what would the 600+HP engine alone cost?
I am not trying to derail your project but I have seen 993 3.6L twin turbo engines listed from $14-18 and can easily put out over 600HP . Did you at all consider going that route?
Good luck with the project and I look forward to seeing it progress.
lin7310948 12-17-2010 09:45 AM
stuff continues to come in! hope to get the Livorsi gauges early next week!http://forums.pelicanparts.com/uploa...1292607881.jpg
911st 12-17-2010 08:06 PM
Watching.
gsmith660 12-17-2010 08:48 PM
Thats a nice looking car! Good luck on your project.
Joe Bob 12-18-2010 09:53 AM
What are you going to do for CV joints and axles? Think the 930 stuff will hold up?
lin7310948 12-18-2010 11:32 AM
i have similar sized cv joints and axles in my other conversion. the 434 sbc conversion develops as much torque, but not as much horsepower. i am counting on the 930 stuff to hold up my driving style. i'm not a pedal to the metal street racer!
911st 12-19-2010 08:23 AM
A V8 seems smother and easer on drive train with 4 power pulses per motor revolution compared to a 6 cylinder at 3 per revolution.
shanghai_todd 01-03-2011 05:34 PM
subscribed. Love seeing more LS conversions.
carsonmx114 01-03-2011 07:21 PM
I can't believe the nerve of you "hot rodders"!! It's blasphemy!! Just joking...I've been watching Todd's for months. I've already spoken with Steve at RH, I'm going to do the same thing as soon as my Master card cools off a bit from my transmission/ interior/ bumper cover purchase. I'm thinking twin turbo LS1 at some point though. I'm also planning on dual cubed radiators behind the front bumper cover...I don't want to give up my trunk space and I have a friend that works at a place that builds custom radiators and intercoolers. I was turned off be the idea at first but, more hp, less weight, and much less money...not a real hard decision for me.
Maxhouse97 01-03-2011 08:02 PM
RUF is building a V8 for their 911s...
lin7310948 01-04-2011 05:06 AM
stuff keeps coming in....Mast Motorsports wiring harness minus the computer and the drive by wire pedal...http://forums.pelicanparts.com/uploa...1294146372.jpg
kiwiokie 01-04-2011 05:25 AM
Continental orange is a pretty rare color that may be worth going back to if you ever repaint. The color really suits the 911.
Yan2947 01-07-2011 04:09 PM
Great project. Looking foward to the posts!
Yan
lin7310948 01-10-2011 08:18 AM
update
Livorsi called this morning and gauges are to be shipped today. the black faced gauges had a white color diffuser that i did not want so that had to be modified...delay my fault! the Mast Motorsports LS7 engine should be complete and dynoed by next monday. i am anticipating 700 to 725 CHP. Gas tank is completed and installed as well as the almost finished radiator and shroud. i am attempting to fully seal the radiator inlet and outlet air so that it does not migrate to the front compartment and hence into the interior. the radiator shroud also encompasses an aluminum bulkhead as a secondary line of defense. this bulkhead will be sealed and have a full width rubber gasket that will seal against the bottom of the hood. my hood is aluminum so the gasket will have to be very soft and as yet is not in place. still have to develop the ducting from the spoiler opening to the radiator cooling side. still much work to be done in the radiator area to improve the appearance.http://forums.pelicanparts.com/uploa...1294676171.jpg
kodioneill 01-10-2011 11:48 AM
Wow, I hope I have that kind of drive ( not the car kind a drive) when I'm 70.
Have fun!!!
daniel911T 01-10-2011 11:57 AM
Seeing as it's a 930, shouldn't you throw on a turbo? You know, just to be true to the original. :D
Besides, is 700+HP really enough? :rolleyes:
Great project, and beautiful car! I look forward to seeing the progress.
-Dan
bfunke 01-10-2011 12:09 PM
I see you also have a max wedge. Add a picture of that motor too (No spears - I know it's not a Pcar). I used to have Mopars. Seeing the current price of old muscle cars makes me sick that I sold my 70 Cuda 440-6 SS car for $2500 but I was a poor college student at the time.
lin7310948 01-10-2011 01:09 PM
sold the maxwedge clone to a friend of mine in Ohio. it was a really nice car and in drag racing form was a 10.2s and 128 plus performer. http://forums.pelicanparts.com/uploa...1294693462.jpghttp://forums.pelicanparts.com/uploa...1294693760.jpg
911JeffS 01-10-2011 02:15 PM
Hey lin-
JD in Ct, Your Turbos looking good. I'm just about getting going on my Targa, between snow,work,fam, tough to make the time but its all good.
mbaran 01-10-2011 02:18 PM
Good Luck! Seems you've almost caught up to me in a very short amount of time!
-Matt
lin7310948 01-14-2011 06:43 AM
still waiting on the livorsi gauges...maybe today. the motor is hopefully completed next week..still awaiting custom oil pan. got the optima red top located in the smugglers box. yes, that is a nylon strap holding the battery down...non-conductive and easy to unsnap! the battery box can be lifted out after unsnapping and removing two cotter pins through the back of the smugglers box. still cosmetic work to do in this area!http://forums.pelicanparts.com/uploa...1295016120.jpg
lin7310948 01-18-2011 03:57 AM
Lovorsi gauges arrived ! the speedometer is a gps and includes the gps antenna which can does not require line of sight. also the tachometer display can be used to check engine conditions with a mode switch which is seperate. the 4 in 1 gauges is almost exact fit for the porsche tach but the other gauges are slightly smaller. now the trick will be to mount the gauges using the porsche friction method with the rubber gasket. this will require a modified gauge cluster faceplate! the gauges include a central wiring harness that fits onto the Mast motorsports drive by wire harness and most gauge inputs come directly from the ECU.http://forums.pelicanparts.com/uploa...1295351772.jpg
http://forums.pelicanparts.com/uploa...1295351805.jpg
lin7310948 01-18-2011 04:11 PM
this gauge package is very informative. utilizing the mode and toggle up and down switches..not shown.. you can set warning limits for any function the engine measures.through the ECU...fuel, oil temp, fuel pressure, oil pressure, etc. also the digital display will provide time and date. the ECU harness feeds information to the contol gauge...tachometer...and the rest of the gauges are daisy chained to this gauge with one simple harness. the gauges are illuminated with red lighting. the gps shows total mileage and trip mileage. too bad it does not calculate speed vs. time performance. interesting system!
lin7310948 01-19-2011 05:26 AM
a picture of the gauge wiring harness. multicolored is power, ground, etc as well as ecu hookups and the daisy chain sends info to each gauge from the tachometer...the master gauge.http://forums.pelicanparts.com/uploa...1295443566.jpg
lin7310948 01-21-2011 08:53 AM
rough pic of gauge package. still have to install indicator lights for signals, hi beam, parking lights. i will wire into the porsche harness for this. computer troubleshoooting light will be red. need to smooth up rough edges, prime and paint black. hope to layout the complete wiring harness this weekend and to see how it will match up to the installation front to rear.http://forums.pelicanparts.com/uploa...1295628717.jpg
lin7310948 01-23-2011 06:36 AM
painted the new dash faceplate for a rough look! not pleased with the fit and finish of the plate as of yet. i most likely will finish it in vinyl. ordered new led indicator lights. i bought some locally but do not like the size. hopefully the new ones will be in by wednesday or thursday of this week. almost finished with the ducting between the front bumper and the radiator. i wanted a tight fit so that the air can only go through the radiator and not between the nose of the car and the rear side of the bumper. i am concerned about the Ruf air intake opening. i do no want to enlarge the grill opening...shame to cut on a genuine Ruf spoiler, but it fits so well that i will if i have to. i plan to run stainless steel mesh in the opening as well..http://forums.pelicanparts.com/uploa...1295793336.jpg
lin7310948 01-24-2011 06:09 AM
a couple of pics...one of the front compartment. wiring and aesthetics not complete but plent of room for a 993 0r 996 donut and lightweight spare plus a couple of small bags. i will use a 944 style aluminum jack which is small and lightweight. also there is a picture of the wiring harness . i will start planning the layout today. plenty of harness to the front of the car and the mast motorsports engine has lots of harness to be hooked up in the engine compartment.several features built into the harness that i will not use, i am going to hopefully be able to route the front portion of the harness through the tunnel. the harness does not show the ecu and the drive by wire pedal. the harness includes all the necessary relays and fuses to operate the engine, fuel pumps, electric fans,starter circuit, alternator, gauge cluster,etc.. the livorsi gauges have a short harness that connects to the main harness for the gauges and the gps speedomter. still have to decide where i want to go through the rear engine compartment bulkhead....will require a sizeable cutout!http://forums.pelicanparts.com/uploa...1295878044.jpg
http://forums.pelicanparts.com/uploa...1295878104.jpg
lin7310948 01-28-2011 05:29 AM
still have not received the mast motorsports motor...on delay due to oil pan issues. not really happy about that but little i can do other than use a factory pan which i do not want to use. starting to splice in the Mast Motorsports wiring harness and the Livorsi gauge harnesses with the 930 factory harness. lots of wires in the mast harness will not be used. i will use led indicator lights in the dash panel for the turn signals, hi beam, park lights, etc. still have to cut a hole in the rear bulkhead for the intake filter, at which time i will pass the engine wiring into the engine compartment. how are you other LS conversion guys doing? snowed in?http://forums.pelicanparts.com/uploa...1296221324.jpg
http://forums.pelicanparts.com/uploa...1296221358.jpg
lin7310948 02-04-2011 09:48 AM
still awaiting the completion of the engine...supposed to receive the oil pan today at Mast Motorsports..we will see! replaced the rear quarter windows this morning...lexan with naca ducts on each side.i already have lexan rear window and side windows in place on the car. the intake will be reversed on the motor as i plan to place the air cleaner in the back seat area...enclosed and fed air via the naca ducts and fkexible tubing. the wiring harness is through the tunnel and up into the front compartment. i am a bit hesitant to start soldering wires but do have the wiring planned out and might just go ahead.http://forums.pelicanparts.com/uploa...1296841639.jpg
pdlightning 02-04-2011 10:07 AM
Excellent! It only cost a few extra dollars to go first class!
Nice choice on the engine and accessories.
Do you have any update pictures?
pdlightning 02-04-2011 10:10 AM
Your post at 9:48 posted as I was asking for more photos, go figure!
lin7310948 02-04-2011 12:01 PM
toggle switches for the GPS speedometer and the tachometer. i will put black rubber covers over the swiches so they blend in more with the dash. indicator lights in place for turn signals, brights, and parking lights. also will have a malfunction indicator light for the ECU located down by the heat/vent controls. i removed the a/c, radio. park brakes, etc. many years ago.hoping to be down close to 2300 pounds weight. the LS7 engine should be 50 t0 75 pounds or more lighter than the turbo engine.http://forums.pelicanparts.com/uploa...1296849597.jpg
aftermath 02-04-2011 12:22 PM
I have a 944 with a LS1, a 930 with a SBC and Im putting a LS7 into a 935 clone.
Im not afraid of conversions :) The renegade guys are great to work with. Maybe when Im 70 ( 25 years from now ) I might have all 3 cars running ! At least it feels that way at the pace Im making....
935 will be getting a LS7 ( I have a short 930 lsd for this already from Renegade).
http://forums.pelicanparts.com/uploa...1296850775.jpg
930 getting the radiator installed by Renegade
http://forums.pelicanparts.com/uploa...1296850650.jpg
944 conversion kit from Renegade also
http://forums.pelicanparts.com/uploa...1296850866.jpg
lin7310948 02-05-2011 07:06 AM
i like the looks of the black car. i almost did the same for my first conversion. several years ago i bought a 935 bodied 76 911 with very few miles from a guy in Hollywood. the fiberglass was extremely thick and heavy. the tail was really heavy. it had more of a 934 front end and i could not appreciate the angular rear with the more rounded front end...so i sold the car. we should start a conversion thread for just SBC and Ls conversions...no subarus. no 928s. etc. to share ideas and experiences among Porsche guys who like v8 power. and, yes! RH has always been very helpful to me.
