decklid clearance. they do make a plastic valve cover without that baffle that would probably clear the regular decklid. this motor sits surprisingly low in there.
http://i50.photobucket.com/albums/f3...ps7b5be092.jpg |
how it sits now. its now just a matter of putting everything back together
http://i50.photobucket.com/albums/f3...ps66c0f8f5.jpg |
Looks great. I absolutely love the wheels! What did you have to do to make them work?
Also, is there an intercooler in the decklid? |
subbed
No intercooler. I need to switch to the plastic 24v valve cover to remove that baffle and i could maybe get it to fit. i need to run my filter as well and that might need to go up in there as its already going to be close to down pipe. i will probably go water/meth injection when i'm ready to turn up the boost. |
Really clean little project. I love the camo.
Finally got the 10 little trim screws i needed to install the rear glass. I used the rope trick. Super easy to do. Gonna try windshield tomorrow.
http://i50.photobucket.com/albums/f3...psaa31db02.jpg Still on that wiring game. http://i50.photobucket.com/albums/f3...ps608bfd9c.jpg |
Had my buddy Stanley weld up some tips, dual 2.5" pipe and made me a smooth 2 into 1 transition. just need to cut a couple more tight 90's and exhaust is done. I'll get some oil and gas in it this weekend and see what happens.
http://i50.photobucket.com/albums/f3...psaef53383.jpg 58'' from turbo to tip. should be rowdy http://i50.photobucket.com/albums/f3...ps0bfaa80b.jpg |
lots of little things to button up but shes on the ground. went to fire it up and the fuel pump was locked up. looked a bit crusty but i thought it would work. nope. new pump on the way
http://i50.photobucket.com/albums/f3...ps594ac785.jpg |
Some of the interior has arrived. need to send off seats soon.
http://i50.photobucket.com/albums/f3...psa695ecdd.jpg |
Worked on the bumper while waiting for fuel pump.
cut some plastic templates http://i50.photobucket.com/albums/f3...ps9f53bc0a.jpg epoxied in http://i50.photobucket.com/albums/f3...ps707703f2.jpg sanded flush http://i50.photobucket.com/albums/f3...ps0c6ca39e.jpg first coat of filler http://i50.photobucket.com/albums/f3...ps5bbee19f.jpg |
exhaust finished. car is running and driving.
http://i50.photobucket.com/albums/f3...psfbf7bebf.jpg http://i50.photobucket.com/albums/f3...ps13fef37a.jpg |
Purty. Need some videos...:)
