Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
Front radiator mount hose routing?
I am going with radiators mounted in the front section of the car for my LS swap and was going to route the radiator hoses/lines through the original location of the factory oil cooler lines on the 964. However, I began thinking that by doing that the highest point in the cooling system may be at the top of the front fenders versus in the rear where the radiator fill cap would be located.
Does anyone have pictures of how their radiator hose line set up looks like running radiators up front?
Thanks.
Old 03-31-2017, 05:26 PM
M491/Targa V8/ 550 Spyder
I purchased a radiator set up from renegade hybrids, works great and I'm running twin turbos. As for the routing they sell a kit but it runs directly under the car. Looks like junk
I'm using a electric water pump with thick wall rubber hose run through the rockers and up around the wheel wells, i pressurize it with a pump dropped into a 5 gallon bucket. Haven't had any problems with air pockets. You can't see the hoses
My radiator cap is a thermostat mounted unit, and I run a overflow bottle
Old 09-12-2017, 05:27 PM
ChrisP911's Avatar
I actually like the way you ran your coolant lines, doe you have any pics of them in the rockers.
Old 05-08-2018, 05:40 PM
check out my cooling system New Project 76 with 993 GT2 Widebody,LS1,Subaru Box,996 Brakes
Old 05-14-2018, 07:50 PM
Where did you buy your fuel cell from?
Old 06-09-2018, 05:51 PM
