Work in Progress
3.0L long block value
I wanted to hear from you guys what you thought a 3.0L long block was worth? Say it has everything except CIS, and a distibutor. The exhaust has been backdated, but is rusty and probably in need of replacement. It also has carrera pressure fed tensioners. The engine is out of a 1980 911Sc, the odometer shows 75,000 miles. I was thinking it would be worth somewhere around 3500 to 3700. The alternator, fan, fanhousing, engine shrowd, and tin are still on the engine.
Do you think I would be better off selling it in parts? Does anyone have rough estimates for values of 3.0L engine parts. Case: Crankshaft: Heads: Pistons/cylinders: Thanks for any ideas you have. Cheers Rich |
Gon fix it with me hammer
i recently flogged off a 3.2 in parts
for an engine and 915 tranny with everything on it, i could barely make 3500 euro's, that's including injection and everything in parts it broke up like this case 500 crank 500 915 with cooler 1250 motronic 230 ( it was untested) heatexchangers , 300 muffler (DP11) 250 hydraulic tensioners and chain housings 300 not sold yet P&C's with visible honing (car had been unused for 10 years) good heads cams and cam towers shroud injectors intake runners alternator ( we kept that for our selves) fan CIS injection parts maybe worth a tad less, dunno but i'de still sell the bugger in parts rather than in 1 piece people can visually verify the condition of the parts rather then buy one package with unknown inner parts...
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Work in Progress
Thanks for the input guys. Stijn I take it all those prices are in Euro's right?
The engine I have is complete with webers and electromotive crank fire ignition, but every buyer I have heard from wants to go CIS. So I was just thinking I can easily take the Crank-fire and webers off and sell those parts seperately. Noah, I know the engine was rebuilt 10 years ago, but I do not know what type of headstuds were used. Is there a way to check the headstud type without taking the heads off? I know none of them are currently broken. The headstud nuts look like the original barrel 10mm hex nuts that are typical in this spot, but beyond that I can't think of any way to know what they are for certain. I've removed the valve covers and none of the headstuds are broken. Also it does have the updated chain tensioners. Thanks again guys I really appreciate the information. Cheers, Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
Work in Progress
Here is a picture of the engine in question:
![]() Some of the engine tin is missing in the picture, but I have all of it. |
most folks want to go with CIS?? that's just crazy unless they are in Cali with smog rules and all... yes the carbs are worth money too, no problem there
